Terminal emulator for 1843200 baud? |
Posted: Thu Apr 23, 2009 1:46 pm |
Sorry if this is off-topic. Don't know where else to ask, and I cant find anything on google.
I'm trying to test how fast I can transmit reliably from a dsPIC30F4011's UART to a PC, over a FT232R USB>Serial breakout board. I've gotten up to 921600 with no problems, but that's as high as hyperterminal or RealTerm will allow you to set the baud rate. With a 7.3728MHz XT and 16x PLL, I should be able to get 1843200 baud.
Does anyone know of a terminal emulator that will allow you to use a baud rate of 1843200? |
treitmey
Posted: Thu Apr 23, 2009 2:25 pm |
In siow from CCS there is an "other" baud option.
I never used it,.. but you could try. |
Posted: Thu Apr 23, 2009 2:54 pm |
on almost any middle age to NEW PC 115200 Kbaud is the speed limit
( using an actual UART)
for windows API mapped stuff like the edgeport USB virtual serial port - 230Kbaud to 460kbaud is it
You will also find that if it is RS-232 levels you are using - then there are ERROR rate vs cable length issues possible too
a max baud rate for things like MAX232 interface adapters needs to be considered too, as the engineered anti-RFI rise/fall time aspects of the MAX232 and its brothers and sisters will bite you too.
you will need a very specialized bit of hardware to get it to a PC
between PICS , with complementary hardware you are better off |
