rodrii
| CAN Bus problem for beginner |
Posted: Thu Apr 16, 2009 12:22 pm |
I have two 18F458 and I want to communicate to each other via CAN bus. I am beginner and that is my first project with CAN. I know that my problem will be very simple for you . If any one helps, I will be happy. There is a led at one node and a button at the other node. I set up this example on the breadboard. I examined EX_CAN.C and other two CAN examples. In fact, I don't know what my problem is. Anyone can see any software wrong?? If there is no wrong on software, I will look at my hardware. Here is my codes and information about project:
-Compiler is PCH C compiler 4.057
-Baud rate is 250Kbps
-Prob. Delay=1 ,Phs_seg1=4,Phs_Seg2=4,SJW=1,Brp=1 and oscillator is 8 MHZ (as you see on codes)
#include <18F458.h>
#device adc=8
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
Transmitter Codes:
#include "C:\Program Files\PICC\Projects\lcd\transmitter.h"
#define CAN_USE_EXTENDED_ID TRUE
#include <can-18xxx8.c>
#define BUTTON PIN_A4
#define tx_id 0x201
#define BUTTON_PRESSED !input(BUTTON)
int buffer[8];
int i;
for(i=0;i<8;i++) {
buffer[i]=0
can_init();
can_set_mode(CAN_OP_CONFIG);
BRGCON1.brp=1;
BRGCON1.sjw=1;
BRGCON2.prseg=1;
BRGCON2.seg1ph=4;
BRGCON2.sam=FALSE;
BRGCON2.seg2phts=FALSE;
BRGCON3.seg2ph=2;
BRGCON3.wakfil=TRUE;
can_set_mode(CAN_OP_NORMAL);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
// TODO: USER CODE!!
if (BUTTON_PRESSED) {
while (BUTTON_PRESSED) {}
delay_ms(200);
can_putd(tx_id, &buffer[0], 1, 1, 1, 0);
Receiver Node:
#include "C:\Program Files\PICC\Projects\lcd\led.h"
#define CAN_DO_DEBUG TRUE
#define PIN_LED1 PIN_A5
#define LED1_HIGH output_low(PIN_LED1)
#define LED1_LOW output_high(PIN_LED1)
#define RESPOND_TO_ID_LED 0x201
struct rx_stat rxstat;
int32 rx_id;
int buffer[8];
int rx_len;
int i;
for(i=0;i<8;i++) {
buffer[i]=0;
can_init();
BRGCON1.brp=1;
BRGCON1.sjw=1;
BRGCON2.prseg=1;
BRGCON2.seg1ph=4;
BRGCON2.sam=FALSE;
BRGCON3.seg2ph=2;
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
while(!can_kbhit());
if ( can_kbhit() ) //message available?.
if(can_getd(rx_id, &buffer[0], rx_len, rxstat)) { //...then get data from buffer
if (rx_id == RESPOND_TO_ID_LED) {
LED1_HIGH;
LED1_LOW;
Posted: Thu Apr 16, 2009 12:44 pm |
| Quote: | #FUSES H4
oscillator is 8 MHZ |
The H4 fuse is not correct if you have an 8 MHz crystal and you want
to run the PIC at 8 MHz. You should use the HS fuse. Change it.
Read this thread for a link to some Loopback code which will allow you
to test each CAN bus node individually to see if they work.
Also, there is test code for two CAN bus boards which are connected
together. It will test if they can communicate with each other:
http://www.ccsinfo.com/forum/viewtopic.php?t=29627 |
rodrii
| thx |
Posted: Fri Apr 17, 2009 2:11 am |
Thank you very much for your quick reply. I don't know how I made mistake like that . From your message I understood that this program is right and if I have a problem about CAN bus, the reason of lack of communication will be hardware.
I also have some questions. If you reply, I will be happier. My CAN bus is on breadboard, is that can be problem?? Is there any simulation program like proteus for PIC?
And can you send me any sample simple program like this? But without pc connections I mean no PC will connect to PICs.
Thank you again for your reply. |
Posted: Fri Apr 17, 2009 11:49 am |
| Quote: |
hardware. |
It could be hardware or software. By using my test programs, you can
prove if your hardware is good. The test programs should work. If
they don't, you likely have a hardware problem which can then be fixed.
First, prove that your hardware is good. Once that is done, then test it
with your own code.
| Quote: |
I don't want to re-write my two-board test program to use switches and
LEDs. It's too much work. |
| ok |
Posted: Sat Apr 18, 2009 4:33 am |
thx again for your reply. at first I will do your program in my hardware...
then I can solve my problem, I think..
If i have a problem, i will post again  |
