romertz
| LCD trouble (dog-162 with 7036 driver) |
Posted: Fri Apr 17, 2009 11:52 am |
Hello all,
I have a circuit that shows data in a lcd...some normal. I have been using a lcd that uses HD44780 driver and using the flex_lcd.c that I found around here. It works without problems using 4 data bits and 3 control bits But for design motives, I had to change the old Lcd to a new one, EA DOGM162S-A from Electronic Assembly that uses ST7036 driver. In over view, they are compatible, except that when I placed it in my circuit, it doesn't do anything. Like it would be turn off. so reading over I found that the driver are compatible but the init sequence. Because this new Lcd requires a contrast set before using it. I inserted the sequence over the flex_lcd library, based on the driver datasheet. But it still doesn't do anything. I have only one Lcd and I don't know if the Lcd is broken or if it's a hardware issue, or if the library is wrong.
Can anyone help me. Some ideas? Thanks in advance.
I will put the two inits, the rest of the library is the same, but I have changed the init secuence.
The new:
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
output_low(LCD_E);
delay_ms(40);
lcd_send_nibble(0x30); //function set
delay_ms(5);
delay_us(50);
delay_us(50);
lcd_send_nibble(0x020); //function set
delay_us(50);
lcd_send_nibble(0x29); //function set
delay_us(50);
lcd_send_nibble(0x14); //internal osc frecuency
delay_us(50);
lcd_send_nibble(0x70); //Contrast set
delay_us(50);
lcd_send_nibble(0x52); //power/icon/contrast control
delay_us(50);
lcd_send_nibble(0x6a); //follower control
delay_us(50);
lcd_send_nibble(0x0C); //display on
delay_us(50);
lcd_send_nibble(0x01); //clear
delay_ms(5);
lcd_send_nibble(0x06); //entry mode set
delay_us(50);
/*lcd_send_nibble(0x33);
delay_ms(5);
lcd_send_nibble(0x32);*/
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
lcd_send_byte(0, LCD_INIT_STRING[i]); //delay_ms(5);
// If the R/W signal is not used, then
// the busy bit can't be polled. One of
// the init commands takes longer than
// the hard-coded delay of 60 us, so in
// that case, lets just do a 5 ms delay
// after all four of them.
#ifndef USE_LCD_RW
delay_ms(5);
The old:
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
lcd_send_nibble(0x03);
delay_ms(5);
lcd_send_nibble(0x02);
#ifndef USE_LCD_RW
delay_ms(5);
where,
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xc, // Display on
1, // Clear display
6 // Increment cursor
Posted: Fri Apr 17, 2009 1:33 pm |
Look at the orginal code. The lcd_send_nibble() function sends the
lower 4 bits of a byte. So, the following code is sending '3'.
| Quote: | for(i=0 ;i < 3; i++)
delay_ms(5);
Here is your code. What are you sending ? You are sending the lower
4-bits of each byte, which is a '0'. You need to change the values below
to 0x03.
| Quote: | lcd_send_nibble(0x30); //function set
delay_ms(5);
delay_us(50);
delay_us(50); |
The change in delay times is OK. The data sheet for your LCD says so.
Now let's look at the rest of your code:
| Quote: | lcd_send_nibble(0x020); //function set
delay_us(50);
delay_us(50);
delay_us(50);
etc. |
And here's the original code:
| Quote: | for(i=0; i < sizeof(LCD_INIT_STRING); i++)
lcd_send_byte(0, LCD_INIT_STRING[i]); |
The original code is using the lcd_send_byte() function, but your code
is calling the nibble function. You need to change it so you're sending
bytes. |
