kianwee92
| Can my program send and receive data through FPGA? |
Posted: Wed Aug 14, 2013 1:48 am |
#include <mcu codes.h>
#include <usb_cdc.h>
#define input_CLK PIN_B0
#define pin_1 PIN_B3
#define input_data PIN_B4
#define input_LED PIN_D1
usb_cdc_init();
usb_init();
usb_wait_for_enumeration();
int1 data[4];
int i;
int1 received_data=0;
int1 data_input=0;
int1 data_input1=0;
output_high(input_LED);
while(!usb_cdc_kbhit())
for(i=0; i<4; i++)
data[i] = i+1;
switch(data[i])
case 1: data[0] = 1;
case 2: data[1] = 0;
case 3: data[2] = 0;
case 4: data[3] = 1;
output_bit(pin_1, data[i]);
output_high(input_CLK);
output_low(input_CLK);
output_low(input_LED);
for(i=0; i<8; i++)
received_data = input_State(input_data);
if(received_data==1)
data_input += received_data;
printf(usb_cdc_putc,"%d", data_input);
if(received_data==0)
data_input1 += received_data;
printf(usb_cdc_putc,"%d", data_input1);
I am getting the output data of 1010 instead of 1001 by using oscilloscope to test on pin_1. _________________ nothing to add |
Posted: Thu Aug 15, 2013 8:23 am |
1) Without telling us what your FPGA is programmed to do, we can't help.
2) Timings seem ludicrous. When I'm clocking things into a shift register on a FPGA, I'm using single cycle delays, if at all. Hundreds of mSec!...
3) There is so much code doing nothing, it is impossible to tell what you intend, or what is going wrong. Seems like the most complex way to load 1,0,0,1 into an array it is possible to write:
int1 data[4] = {1,0,0,1};
4) Avoid declaring variables mid function. Understand that standard C, _does not allow this_. It is _supposedly_ supported in CCS, but is one of those things that has the 'habit' of causing problems. Stick to the standard C format, with variables always declared at the start of a function, or code block.
5) You are incrementing single bit variables. Does this make much sense?....
Yes, plenty of people clock data into, and out of shift registers built using FPGA's, with a PIC.
As a further comment, realise that generating a clock and data stream for data, is what SPI does. Even for an 'odd' transmission length like 4 bits, the supplied software SPI can do this.
