Please go to www.mcuspace.com/mcuforum for posts concerning PIC®MCU
16x2 LCD 8 Data bit ready code for every one
Nisar
PostPosted: Sat Mar 28, 2009 3:02 am     Reply with quote
8-BIT LCD DRIVER FOR PIC16F877A CCSC
//  CCS C Compiler
// LCD 16x2
// by Nisar Ahmed
// 2009/03/27
#include <16F877.h>                           // PIC16F877 header file
#use delay(clock=4000000)                       // for 4Mhz crystal
#fuses XT, NOWDT, NOPROTECT, NOLVP              // for debug mode
#define PORT_A                  0               // define for function output()
#define PORT_B                  1
#define PORT_C                  2
#define PORT_D                  3
#define PORT_E                  4
#define NCHAR_PER_LINE          16              // max char numbers per line
#define LCD_RS                  PIN_A1
#define LCD_RW                  PIN_A2
#define LCD_E                   PIN_A3
#define LCD_DAT                 PORT_D
///////////////////////////////////////////////// output()
//lcd data bus output
void output(int8 port, int8 dat)
        switch(port)
                case PORT_A: output_a(dat);      break;
                case PORT_B: output_b(dat);      break;
                case PORT_C: output_c(dat);      break;
                case PORT_D: output_d(dat);      break;
                case PORT_E: output_e(dat);      break;
                default :       //??? port maybe error!
}//end output()
//////////////////////////////////////////////// lcd_write_cmd()
void lcd_write_cmd(int8 cmd)
        delay_us(400);
        output_low(LCD_RS);
        output_low(LCD_RW);
        output(LCD_DAT, cmd);
        output_high(LCD_E);
        delay_us(400);
        output_low(LCD_E);
}//end lcd_write_cmd()
/////////////////////////////////////////////// lcd_write_dat()
void lcd_write_dat(int8 dat)
        delay_us(400);
        output_high(LCD_RS);
        output_low(LCD_RW);
        output(LCD_DAT, dat);
        output_high(LCD_E);
        delay_us(400);
        output_low(LCD_E);
}//end lcd_write_dat()
//////////////////////////////////////////// lcd_init()
void lcd_init(void)
        output_low(LCD_E);              // Let LCD E line low
        lcd_write_cmd(0x38);            // LCD 16x2, 5x7, 8bits data
        delay_ms(15);
        lcd_write_cmd(0x01);            // Clear LCD display
        delay_ms(10);
        lcd_write_cmd(0x0f);            // Open display & current
        delay_ms(10);
        lcd_write_cmd(0x06);            // Window fixed
        delay_ms(10);
}//end lcd_init()
///////////////////////////////////////// lcd_display_char()
void lcd_display_char(int8 line, int8 pos, int8 ch)
        int8 tmp;
        line = (line==0) ? 0 : 1;
        pos  = (pos >NCHAR_PER_LINE) ? NCHAR_PER_LINE : pos;
        tmp = 0x80 + 0x40*line + pos;
        lcd_write_cmd(tmp);
        lcd_write_dat(ch);
}//end lcd_display_char()
/////////////////////////////////////////// lcd_display_str()
void lcd_display_str(int8 line, char str[])
     int8 i;
        for(i=0; i<NCHAR_PER_LINE; i++)
                lcd_display_char(line, i, ' ');
                if(str[i] == '\0') break;
                lcd_display_char(line, i, str[i]);
}//end lcd_display_str()
        char LINE2[] = { "PIC16F877 CCSC " };
        int8 i;
                lcd_display_char(0, i, '0'+i);
        //lcd_display_str(1, "PIC16F877A CCSC ")   //CCSC can't compile
        lcd_display_str(1, LINE2);
}//end main()
Regards
Nisar ahmed
mohamed.tajelsir
Your code works with me 18F4550
PostPosted: Thu Oct 06, 2011 7:15 am     Reply with quote
Thanks, You saved my time!
