Why Is EEPROM Data Erased?
boulder
PostPosted: Tue Mar 24, 2009 5:13 pm     Reply with quote
I wrote a very simple code to write 22 byte to EEPROM from address 0 to 21 and read data back successfully.
#include <16F689.h>
#include <stdio.h>
#include <stdlib.h>
#use delay(clock=3686400, crystal)
#use rs232(baud=115200, xmit=PIN_B7, rcv=PIN_B5)
#fuses XT, NOWDT, PUT, MCLR, NOPROTECT, NOCPD, NOBROWNOUT, NOIESO, NOFCMEN
unsigned int8 i;
  for(i=1; i<=22; i++)
    write_eeprom(i-1, i);
  for(i=0; i<=21; i++)
    putc(read_eeprom(i));
However, if I recompile the code without write_eeprom() and power reset, I read back 0xFF from the same eeprom chip.
#include <16F689.h>
#include <stdio.h>
#include <stdlib.h>
unsigned int8 i;
Could anybody tell me what I am missing in my code? My compiler is 4.085 and MPLAB IDE is 8.15a.
Thanks.
PostPosted: Tue Mar 24, 2009 5:47 pm     Reply with quote
It's a setting in the programmer's options. See this link for ICD2:
http://www.ccsinfo.com/forum/viewtopic.php?t=33108
boulder
PostPosted: Tue Mar 24, 2009 6:07 pm     Reply with quote
But I am using PICKit2 instead of ICD2. I do not see the option of preserve EEPROM data.
Thanks.
PostPosted: Tue Mar 24, 2009 6:48 pm     Reply with quote
In MPLAB 8.20a, if you select PicKit2 as the programmer and then go to
the Programmer menu and click on Settings, a dialog box will appear.
In the Settings tab, it has a tickbox for "Preserve Device EEPROM".
If you don't have that option, then I suggest you upgrade MPLAB.
boulder
PostPosted: Tue Mar 24, 2009 8:59 pm     Reply with quote
PCM,
Thanks. You are right, the latest version of MPLAB, 8.20a has this option for PicKit2.
I have one more question about read data eeprom. Does it need to add delay between reading each byte data from eeprom? If the answer is yes, what's the minimum delay?
Thanks.
PostPosted: Tue Mar 24, 2009 9:33 pm     Reply with quote
There is no delay for reading. For writing, the delay is handled by the
CCS compiler in the write_eeprom() function. You don't have to do anything.
