how to run #int_ext with tiny bootloader
tapasdas000
PostPosted: Thu Apr 02, 2009 7:32 am     Reply with quote
Hi I am using tinyPIC bootloader 16f877a 20 mhz but I am unable use int_ext.
Can anybody help ?
I have already tried this code:
#build(reset=0x1, interrupt=0x8)
#ORG 0x0F00,0x0FFF {}
But no use.
With hardware it's not working. Embarassed
Heath
PostPosted: Thu Apr 02, 2009 8:34 am     Reply with quote
Post a simple program that illustrates your problem please.
tapasdas000
THANKS FOR RESPOND
PostPosted: Thu Apr 02, 2009 1:03 pm     Reply with quote
My code is simple test code.
Actually I am interfacing PIC16f877a with cc1100 Texas IC which is a 1 ghz transceiver
Initially I am checking external interrupt with simple test code. I am a new user to this Tiny bootloader. I am using it because my laptop doesn't support serial port so I am using usb to serial converter. But winpic programmer doesn't support this usb to serial converter so I my only option is this Tiny bootloader.
So I have to test if the external interrupt is working so that I can use it for my above application later.
So here is my test code:
#include<16f877a.h>
int x;  //global variable
//Here is the ISR
# INT_EXT
 PortB_Interrupt()
 x=x+1;
  x = 1; //Initialize x
   OPTION_REG=0x07;   //portb pull up
     enable_interrupts(GLOBAL);  //Turn on interrupts
     enable_interrupts(INT_EXT); //Enable INT_EXT
   ext_int_edge( H_TO_L  );
  while(1) {
   output_c(x);
and my tyni bootloader version is 1.9.8
with the mplab simulator its works fine but with hardware it is not working
i think some probelem with interrupt vector 0x0004
PostPosted: Thu Apr 02, 2009 3:12 pm     Reply with quote
Hi
Maybe first try your code without the boot loader, if working try it with the loader.
You miss all the
#FUSES
And when I use the boot loader I don't use any of:
And try to use CCS way to make init of the PIC:-)
tapasdas000
PostPosted: Thu Apr 02, 2009 7:00 pm     Reply with quote
hi thanks but I did not miss
#FUSE
but I am using my own header file and in that I have made #FUSE and my #FUSE is
 #FUSES XT, BROWNOUT, NOWDT,NOLVP
I want to tell that my code is working fine except the interrupt part.
You maybe ignored it but I have initialized
x=1;
and am outputting it on portc by
output_c(x);
and I am getting Port C as 1 on my hardware using the Tiny bootloader. The rest of the code is working fine except the isr part.
So is there any solution to it?
Question Question Question Sad
tapasdas000
PostPosted: Fri Apr 03, 2009 2:52 am     Reply with quote
please is there any export out there who can help me with the above problem Rolling Eyes
