camus_agf
| CCS CAN Bus C library in SAEj1939 applications ??? |
Posted: Tue Mar 24, 2009 8:46 am |
Hello , I have a doubt :
In the PCWH compiler from Hi-Tech , and in MikroC compiler, we have a CAN library in C language for MCP2515. This library doesn't mention anything about SAE j1939 support.
So, I'm doubt is about if we can use this library in SAE j1939 applications ???
I also know about J1939 C Library for PIC16 Microcontrollers and MCP2515 User’s Guide, but this library is not so easy to use like CAN Bus library from PCWH Compiler.
I want to design a scan tool, so I just need listen the Bus not write in. What library do you recommend ??
Someone can help me on this ?? |
