choosujin
Joined: 24 Aug 2010 Posts: 3 Location: south korea, incheon,
| help me! it does not work (interrupt, timer1) |
Posted: Sun Nov 14, 2010 7:56 pm |
Hi everyone.
This is below my codes...to use time clock. (sorry, i'm not native).
It doesn't work - interrupts routine.
What is problem in my codes? plz, tell me what are problems.
My devices are 16f877a, ccs-c V.4.008 compiler, picdem2 board, icd2.
#include<16f877a.h>
#fuses xt,noprotect,nowrt,nobrownout,nolvp,nocpd,put
#zero_ram
#byte porta=0x05
#byte portb=0x06
#byte portc=0x07
#byte trisc=0x87
#byte trisa=0x85
#byte trisb=0x86
int cnt=0;
#int_timer1
void timer1_isr()
cnt++;
if(cnt%2==1)
portb=0xff;
portb=0x00;
set_timer1(32768);
trisa=0xff; trisb=0x00;
// trisc=0xff;
portb=0; portb=0xff;
set_timer1(32768);
setup_timer_1(T1_EXTERNAL);
//32.768hz ,portc.0(T1oso),portc.1(T1osi)
setup_timer_1(T1_DIV_BY_1);
setup_timer_1(T1_CLK_OUT);
enable_interrupts(int_timer1);
enable_interrupts(global);
while(1) {
<--continous loop..
Posted: Sun Nov 14, 2010 8:58 pm |
| Quote: | setup_timer_1(T1_EXTERNAL);
This is wrong. CCS functions don't work with sequential calls.
The parameters must all be in place for just one call to the function.
The .h file for your PIC explains how to do this. Here is an example
of the correct method:
| Code: | | setup_timer_1(T1_EXTERNAL | T1_DIV_BY_1 | T1_CLK_OUT); |
This line will setup Timer1 to work with the external oscillator, with a
32.768 KHz crystal on the T1OSC pins. The PicDem2-Plus board has
this crystal on those pins.
Also, vs. 4.008 is a bad version to use. It's too early in the vs. 4.000
series. It has bugs. It's better to use at least vs. 4.068, and preferably
a version much later than that. Vs. 4.008 might work for some very
simple code. It might work for your program here. But if you try to do
any more complicated programs, you will find some compiler bugs. |
