IF statement and push buttons
matt1eg
PostPosted: Wed Mar 18, 2009 7:01 pm     Reply with quote
Hi
I think I'm just being stupid but I can't get a sub-routine to work as I need it. It is meant to detect what button is pushed and then do something accordingly. All works except one statement. This is the last else if
else if(!input(CANCEL)){
         printf(lcd_putc,"\f\n   ARE YOU SURE?");
         printf(lcd_putc,"\n\nYES = SEL   NO = CAN");
         delay_ms(200);
         if(!input(SELECT)){
            printf(lcd_putc,"\f\n     CANCELLED");
            delay_ms(1600);
            continue;
            delay_ms(250);
When either button is pressed it doesnt do the action in the sub if and else but the action of the button in the while loop. The code is below which should help me make sense more
void Set_Tariff()
   Tariff = 0;
   printf(lcd_putc,"\f    ENTER TARIFF\n",);
   printf(lcd_putc,"%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c%c",0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,
                                 0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06);
   printf(lcd_putc,"    %2.1fp PER UNIT\n",tariff);
   printf(lcd_putc,"\nMORE = +   LESS = -");
   while(Tariff_Set==FALSE){
      if(!input(INCREMENT)){    //This Works fine
         Tariff += 0.5;
         delay_ms(200);
         printf(lcd_putc,"\f    ENTER TARIFF\n");
         printf(lcd_putc,"    %2.1fp PER UNIT",tariff);
      else if(!input(DECREMENT)){       //This Works fine
         Tariff -= 0.5;
         delay_ms(200);
      else if(!input(SELECT)){     //This Works fine
         Tariff_Set = TRUE;
         delay_ms(200);
      else if(!input(CANCEL)){    // This is the Problem
         delay_ms(200);
         if(!input(SELECT)){
            printf(lcd_putc,"\f\n     CANCELLED");      //If I press 'select' it does the previous statement
            delay_ms(1600);
         else if(!input(CANCEL)){      //Same kind of issue here
            continue;
            delay_ms(250);
I'm sure its just my fairley basic knowledge of C but I don't know a way around it or to sort it.
Any suggestions welcome
Cheers
Wayne_
PostPosted: Thu Mar 19, 2009 3:33 am     Reply with quote
First problem, it will always do the previous condition if SELECT is pressed, you need to change it so that it only does this if CANCEL is NOT pressed!
      else if(input(CANCEL) && !input(SELECT)){     //This Works fine
         Tariff_Set = TRUE;
         delay_ms(200);
         delay_ms(200);
         if(!input(SELECT)){
            delay_ms(1600);
         else {      //Don't need to do a check here as we already know CANCEL is false!
            continue;
            delay_ms(250);
