		| Author | Message |
		| cfernandez
				| FAT Question |
				|  Posted: Sun Mar 22, 2009 8:17 pm |   |
				| Hi,
 I want to use the FAT driver from CCS with a ATMEL dataflash, anybody make this?, Is possible?
 Thank you very much!
		| FvM
				|  Posted: Mon Mar 23, 2009 12:15 am |   |
				| It should be usable (with some adaptions). Basically FAT can be used with any block addressable media. But you must observe this DataFlash requirement:
  	  | Quote: |  	  | To preserve data integrity, each page of a DataFlash sector must be updated/rewritten at least once within every 10,000 cumulative page erase/program operations. |
 A simple algorithm is suggested in the datasheet, but it requires a non-volatile page pointer.
 P.S.: I noticed, that newer DataFlash datasheets are using the term endurance, which has been apparently unknown at Atmel in the past. They specify 100k erase/write cycles at minimum. It's doubtful, if DataFlash should be used without a wear-leveling flash translation layer for FAT, that is permanently to some sectors (directory and FAT).
 | You cannot post new topics in this forum You cannot reply to topics in this forum
