viknes1985
| Timing issue |
Posted: Thu Mar 05, 2009 2:54 am |
i wanted to read a pin's state.
1. | Code: | | current_bit = PORTB |
read all the bits and evaluate PIN_B0 (believe this is do faster reading)
or
2. | Code: | | current_bit = input(PIN_B0) |
i worry about the time may taken by input(PIN_XX) statement. So which is the registry hold the value for each pin?
Thanks in advance |
Ttelmah Guest
Posted: Thu Mar 05, 2009 3:26 am |
Three different things here:
First, the internal input and output functions, whether for a bit, or a whole port byte, have two basically different modes of operation, according to whether FAST_IO is selected. If this is selected, then these functions operate _exactly the same_ as doing direct bit/byte I/O on the port. If not, extra instructions are added to automatically update the TRIS register. This latter is convenient, since it avoids TRIS errors (probably the commonest thing to get set wrong on a PIC), _but_ at a cost in speed.
Second, if FAST_IO is enabled, and you do a direct bit read or set, using:
current_bit = input(PIN_B0);
//or
output_high(PIN_B0);
Then the output evaluates to just a single machine instruction - no faster possible, while the input will take just one two instructions (but three instruction cycles) to read the bit, and set the bit/byte in the result. Again as efficient as possible.
Third option, manually doing this. A shown here, if you actually want a 'bit', then this is by far the least efficient, since it'll take as many instructions to read the byte as reading and testing the bit, and then you still have to test the bit as more instructions....
If you want to leave the port with automatic I/O selection (and not set FAST_IO), but override this to do a single bit access, then the fastest route, is:
//Assuming you have PORTB already defined
#bit MyB0=PORTB.0
current_bit=MyB0;
This will do the same as the input(PIN_B0) instruction, but will not affect the TRIS, whether or not FAST_IO is selected.
viknes1985
| thanks |
Posted: Thu Mar 05, 2009 4:01 am |
| thanks for the quick reply Ttelmah. |
viknes1985
| i'm using int_rb |
Posted: Mon Mar 09, 2009 9:58 am |
Hi Ttelmah,
I tried as you said, but the bit is always high.
Clarification :
I'm using int_rb to detect the changes in B4 (PIN_B4), so I used set_tris(0x10);
Basically I want to get the bit, which cause the interrupt.
If I never set tris, how do the PIC knows that I'm using B4 as input. Any suggestion?
Thanks in advance |
viknes1985
| read the pulse status |
Posted: Mon Mar 09, 2009 10:49 am |
Using interrupt coz alot of problem, using fast i/o solved the problem....
Ttelmah Guest
Posted: Mon Mar 09, 2009 11:19 am |
A couple of comments.
First, you enable the global interrupt, but never enable INT_RB....
Then, you are clearing RBIF in the interrupt. This is a waste of time. The compiler already does this for you, unless you add the 'NOCLEAR' directive to the interrupt declaration.
Then, you don't declare FAST_IO, and you perform an output_low instruction, TRIS will be being updated for you. Do you want this?.
You are also using the flex LCD driver. What does this say about TRIS?. Would it support using fast_io?. Does it update TRIS?.
viknes1985
| enabling is seems to ok |
Posted: Mon Mar 09, 2009 12:37 pm |
Hi Ttelmah,
i'm using RBIE
| Code: | #byte INTCON = 0x00B
#bit RBIE = INTCON.3 //int_rb enable/disable
do i still need to enable INT_RB in main? as you may see, i enabling the interrupt only at certain times.
output_low()... is just connected to LED to get to know when it's passed the programming code...
i got flex_lcd.c from code library in this forum, uploaded by PCM programmer(thanks to him). I just go through it, no function interfere with other ports. I'm using only port D as output to LCD. |
