replacing putc with write to TXREG
mshearer
PostPosted: Thu Mar 05, 2009 5:08 am     Reply with quote
I'm having a bit of a problem with using the TXREG.
I'm trying to output a chain of hex values
00 A1 F2 C4 40 00 00 00 00 00 F0 00 01 01 00 00
when i use putc(); i get the correct 16bytes out.
However if i use writes to TXREG, with the USART setup all done manually i get
   while(!bit_TXIF)
     continue;
    reg_TXREG = byte_out;
00 A1 F2 C4 00 40 00 00 00 00 00 F0 00 00 01 00 01 00 00
i try narrow down the code and post it up, just wondering if anyone else has come across this.
any help would be great
matt[/code]
mshearer
PostPosted: Thu Mar 05, 2009 6:00 am     Reply with quote
example source
Im working on a PICDEM baord with a 10MHZ crystal. Aiming to work at 9600baud, odd parity
#include <18F4520.h>
#fuses   H4
#fuses   NOWDT
#fuses   WDT128
#fuses   NOPROTECT
#fuses   NOBROWNOUT
#fuses   NOPUT
#fuses   STVREN
#fuses   DEBUG
#fuses   NOLVP
#fuses   NOWRTB
#fuses   NOWRTC
#fuses    NOCPD
#fuses   NOCPB
#fuses   NOEBTR
#fuses   NOEBTRB
#define ZERO        0x00
#define ONE         0x01
#define TWO         0x02
#define   ONE_BYTE   0x08
#define TWO_BYTES   0x10
#define THREE_BYTES   0x18
typedef  unsigned    char     uchar_t;
typedef  unsigned    int      uint8_t;
typedef  unsigned    long     uint16_t;
   #byte reg_TXREG  =  0xFAD
   #byte reg_RCREG  =  0xFAE
   #byte reg_SPBRG  =  0xFAF
   #byte reg_TXSTA  =  0xFAC
   #bit bit_CSRC       =  reg_TXSTA.7
   #bit bit_TX9          =   reg_TXSTA.6
   #bit bit_TXEN        =   reg_TXSTA.5
   #bit bit_SYNC        =   reg_TXSTA.4
   #bit bit_SENDB      =   reg_TXSTA.3
   #bit bit_BRGH        =   reg_TXSTA.2
   #bit bit_TRMT         =   reg_TXSTA.1
   #bit bit_TX9D         =   reg_TXSTA.0
   #byte reg_RCSTA         =   0xFAB
   #bit bit_SPEN         =   reg_RCSTA.7
   #bit bit_RX9         =   reg_RCSTA.6
   #bit bit_SREN         =   reg_RCSTA.5
   #bit bit_CREN         =   reg_RCSTA.4
   #bit bit_ADDEN         =   reg_RCSTA.3
   #bit bit_FERR         =   reg_RCSTA.2
   #bit bit_OERR         =   reg_RCSTA.1
   #bit bit_RX9D         =   reg_RCSTA.0
   #byte reg_PIR1           =    0xF9E
   #bit bit_RCIF         =   reg_PIR1.5
   #bit bit_TXIF         =   reg_PIR1.4
   #byte reg_BAUDCON      =   0xFB8
   #bit bit_BRG16         =   reg_BAUDCON.3
   #bit bit_WUE         =   reg_BAUDCON.1
   #bit bit_ABDEN         =   reg_BAUDCON.0
void send_byte(char);
void parity_errorGeneration(uint8_t cms_tx_message);
   int i;
   char in = 0x00;
   char a[] = {0x00,0xA1,0xF2,0xC4,0x40,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0x01,0x01,0x00,0x00};
   bit_TX9      =   TRUE;
   bit_TXEN   =   TRUE;
   bit_SYNC   =   FALSE;
   bit_SENDB   =   FALSE;
   bit_BRGH   =   FALSE;
   bit_SPEN   =   TRUE;
   bit_RX9      =   TRUE;
   bit_SREN   =   FALSE;
   bit_CREN   =   TRUE;
   bit_ADDEN   =   FALSE;
   bit_BRG16   = 0;
   bit_WUE      = 0;
   bit_ABDEN   = 0;
   reg_SPBRG   = 0x40;
      if(bit_RCIF == TRUE)
         in = reg_RCREG;
         for(i=0;i<16;i++)
            send_byte(a[i]);
void send_byte(char c)
   parity_errorGeneration(c);
      while(!bit_TXIF)
        continue;
       reg_TXREG = c;
   uint8_t tx_bit_count  = ZERO;
   uint8_t tx_loop_count = ZERO;
   for(tx_loop_count = ZERO; tx_loop_count < ONE_BYTE; tx_loop_count++)
      if((cms_tx_message & ONE) == TRUE)
         tx_bit_count++;
      cms_tx_message >>= 1;
   if((tx_bit_count & ONE) == FALSE)
     bit_TX9D = TRUE;
      bit_TX9D = FALSE;
FvM
PostPosted: Thu Mar 05, 2009 6:55 am     Reply with quote
Your homebrewed putc() should work, although an exact equivalent would be two ASM instructions shorter
while(!bit_TXIF);
reg_TXREG = c;
Why aren't you using putc(), may be an inline variant?
But it's possibly incorrect to set TX9D during transmission of the previous character, as you do. I thought, odd parity would be provided by the UART itself, did I miss something?
mshearer
PostPosted: Thu Mar 05, 2009 7:21 am     Reply with quote
I have concerns that using compiler functions might be called up by a safety board at a later date. Any experience of this with the likes of putc() ?
The USART takes care of parity if you use
#use rs232()
but not when your doing it manualy, i think.
Ah so you think that the TX9D bit might be changing while previous bytes are still in the buffer?[/code]
mshearer
PostPosted: Thu Mar 05, 2009 7:58 am     Reply with quote
changing the position of the parity generation seems to have done it.
      while(!bit_TXIF)
        continue;
       reg_TXREG = c;
thank you very much Smile
FvM
PostPosted: Thu Mar 05, 2009 8:08 am     Reply with quote
I see, that PIC18 actually has no hardware parity generator as most uP have. I wasn't yet aware of. The CCS C built-in parity code should be supposed more effective. I don't see a particular reason not to use built-in functions. They may be faulty, but compiler implementation of simple C expressions can be as well.
andreluizeng
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Mar 05, 2009 1:51 pm     Reply with quote
you may also try this code:
void SendByte (char Data)
   char Aux;
  // wait for xmit shifter
   while (! TRMT);
  // wait txif
   while (! TXIF);
   TXREG = Data;      // load TXREG with data
    while (! TXIF);    // wait until transmission ends
   return;
it works fine here.
regards
Andre
