tachometer with pic16f887
Goto page Previous  1, 2
PostPosted: Wed Mar 04, 2009 12:25 pm     Reply with quote
//porturi();
//front_display2();
//temperatura();
//ccp1_isr();
ccp1_isr();
turometru();
//voltmetru();
//rezervor();
//alternator();
//temperatura();
Here, you are attempting to call the isr. Don't do that.
The isr is called automatically when an interrupt occurs. You don't
call it yourself. You need to learn about micro-controllers.
Also, you are constantly calling your turometru() routine. That routine
initializes everything. You don't do that. You initialize everything one
time, at the start of the program.
Look at the thread on the tachometer code. You will not see all the stuff
that you're doing above, in that code. Please follow the code example.
soulraven
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Mar 04, 2009 12:39 pm     Reply with quote
and how should I call subrutina? turometru ();
where ....
if you get out of while (1)
no longer works
PostPosted: Wed Mar 04, 2009 12:46 pm     Reply with quote
This is the original thread. Look at the code that I posted in that thread.
It shows how to do it.
http://www.ccsinfo.com/forum/viewtopic.php?t=29963
Page 2 of 2
