| View previous topic :: View next topic   |
			Thorsten Guest
				| SPI Timer2 CLK doesn't work if SPI_H_TO_L is set |
				 Posted: Sat Feb 28, 2009 12:40 pm     |
I'm using a PIC18F24J10 and i need a max. 70kHz SPI Clock. The PIC have a 10MHZ ocsillator. So I decide to use the Timer2 as SPI Clock source. But that works only if the SPI is set to SPI_L_TO_H but not on SPI_H_TO_L. I am using 4.057.
Could anyone help me on my problem?
Thorsten |
				 Posted: Sat Feb 28, 2009 4:54 pm     |
				What chip are you using as the SPI slave ?    Normally, the data sheet
for the slave chip will specify the required SPI mode.  The SPI mode will
be one of these four modes:
 	  | Code: | 	 		  // SPI modes
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)  |
Normally we prefer to use these constants for the SPI mode, instead
of using "SPI_L_TO_H", etc., because it's easier.
Post a link to the web page for the SPI slave chip.
There is an errata on using Timer2 as the source for the SPI clock
for some PICs.  I don't see this bug listed on the errata sheet for
the 18F24J10, but it still could be present (but not admitted yet by
Microchip). |
			Thorsten Guest
				 Posted: Sun Mar 01, 2009 1:08 am     |
i´m using a QT1106 Wheel IC. Please google for the Datasheet because i can´t post the link (GUEST Acount ) The SPI Mode must be Mode 3. Any more suggestions?
Thanks fpor help.
Thorsten |
			Thorsten Guest
				 Posted: Sun Mar 01, 2009 2:02 am     |
				Yes, i use this setting. I just tried it on a PIC18F87J10 with the same result.
I will try it now on a PIC16. I will inform you about the result.
Anymore Hints?
Greetings
Thorsten |
			Thorsten Guest
				 Posted: Sun Mar 01, 2009 2:21 am     |
				| On a PIC18F452 it works. |
