Stepping over delay_ms() in debugger
PostPosted: Fri Feb 27, 2009 9:35 pm     Reply with quote
I have PCM 4.086 and MPLab 8.20 and a PICKit2 and a 16F886 chip. When I am debugging and try to step over the delay_ms() function, the program jumps to the #use delay statement and gets stuck. At that point, I cannot stop or restart the program. I must reconnect with the debugger to get unstuck. Is this a normal issue? Are there any tricks to avoid this? I suppose I could always put a breakpoint after the delay statement and run to it, but that is awkward. Any ideas?
PostPosted: Sun Mar 01, 2009 1:24 am     Reply with quote
This is really a Microchip issue. Here are a few threads on it from their forum:
http://www.microchip.com/forums/tm.aspx?m=238493
http://www.microchip.com/forums/tm.aspx?m=25775
http://www.microchip.com/forums/tm.aspx?m=291963
PostPosted: Sun Mar 01, 2009 12:17 pm     Reply with quote
Thanks, those links helped me understand what is happening a bit better.
