		| Author | Message |
		| that guy Guest
				| displaying values on LCD |
				|  Posted: Fri Feb 27, 2009 2:46 pm |   |
				| I have a PIC 18f4520 that i am using with the PICDEM 2 Plus demo board, the Rohs version.  I can output stand text, but now I want to output a value.
  	  | Code: |  	  | #include <18F4520.H>
 #use delay(clock = 4000000)
 #define LCD_POWER  PIN_D7
 #include "Flex_LCD.c"
 int num = 0;
 output_high(LCD_POWER);  // Turn on power to LCD
 output_low(LCD_RW);      // Set R/W pin on LCD to a low level
 lcd_init();              // Initialize the LCD
 lcd_putc('\f');
 while(true);
 lcd_putc(num);
 delay_ms(250);
 num++;
		| Ttelmah Guest
				|  Posted: Fri Feb 27, 2009 2:55 pm |   |
				| 'num', is a binary value, starting at 0, and incrementing by one each time round the loop. 'putc', outputs a _single_ character. So, your code will print every possible character from 0 to 255. Look at 'printf', which converts values into their ASCII format for output.
 printf("%d\n\r",num);
 Read the manual to work out what the other characters here are doing.
		| PCM programmer
				|  Posted: Fri Feb 27, 2009 3:07 pm |   |
				| Also, please don't start a new thread every time you have a new question about displaying characters on an LCD.  You already have an existing
 thread on the topic, here:
 http://www.ccsinfo.com/forum/viewtopic.php?t=37985
 You can add new questions to the existing thread.
		| Guest
				|  Posted: Fri Feb 27, 2009 3:50 pm |   |
				| I tried the printf command but it is still not working.  When I tried the printf it gave me the error STDOUT not defined (may be missing #use rs232).  I know C and C++ programming so I understand what the notations are doing, I'm just new to this compiler and just need to get use to it.
  	  | Code: |  	  | #include <18F4520.H> #fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
 #use  rs232           //Do I need this
 int num = 0;
 lcd_putc('\f');
 while(true);
 delay_ms(250);
 num++;
		| Ttelmah Guest
				|  Posted: Fri Feb 27, 2009 3:52 pm |   |
				| As I said, _read the manual_. By default, all commands talk to STDIO. You want to talk to lcd_putc. Look at the entry for printf, and it shows how to do this.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
