| clock problem with pic18f2550 |
Posted: Sat Feb 14, 2009 10:16 am |
Hello everybody!
This is the fist time I am using C (ccs 4) for writing pic programs, before I always used asm. But I am having some problems with the frequency. Right now I just try to turn on/off a led with a PIC18F2550.
But the clock frequency is not working correctly.
First I used the internal clock at 8Mhz, but for a simple loop of 500 ms it needs 2 seconds!!! This code turns off and on the led again in 4 seconds (instead of 1 second).
#int_TIMER0
void TIMER0_isr(void)
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_TIMER1|OSC_31250|OSC_PLL_OFF);
// TODO: USER CODE!!
output_toggle(PIN_A0);
#include <18F2550.h>
#device adc=8
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4 //System Clock by 4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#use delay(clock=8000000)
//#use rs232(baud=9600,parity=N,xmit=PIN_B6,rcv=PIN_B7,bits=8)
So, I decided to use a normal 20 Mhz Xtal.
In this time it is worse, instead of working 4 times slower, it is working 20 times slower. The led stays 10s on, and then 10s off... and this is the code of it:
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);
setup_vref(FALSE);
disable_interrupts(GLOBAL);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
#device adc=8
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES PLL1 //No PLL PreScaler
#FUSES CPUDIV1 //No System Clock Postscaler
#FUSES NOUSBDIV //USB clock source comes from primary oscillator
#use delay(clock=2000000)
//#use i2c(Master,Slow,sda=PIN_B0,scl=PIN_B1,force_hw)
I would be very grateful if you can help me with this I am not sure on what I am doing wrong...
thanks a lot!!!
PD: I was using the wizard for the configuration |
Posted: Sat Feb 14, 2009 1:40 pm |
| Your delay definition shows 2Mhz... |
Posted: Sun Feb 15, 2009 7:21 am |
Sorry, I confused, normally it is 20Mhz, I just changed it to 2Mhz, to see how it was affected. The conclusion was that delay_ms where 10 times faster, but the timer interruptions where as slow as before. So I do not know why the clock is going much slower (with the extarnal Xtal and the internal clock).
And I do not know why is this. :( Does anybody see anything wrong in the configuration #FUSES?
Thanks again  |
Posted: Sun Feb 15, 2009 10:29 am |
You have not told us what you expect the timer to do.
You show no code that involves the timer at all...
However some comments:
You are enabling two interrupts, but only show a handler for one. This _will_ cause disaster. You _must_, have a handler present for any interrupt you enable.
However you then don't enable the global interrupt, so no interrupts are going to occur.
Timer0, on a system at 20MHz, with your 'setup', will call it's interrupt every:
20000000/(4*32*65536)th second
2.384 times per second.
At 8MHz, every 1.04 seconds.
