sf
| PORTb Int_ext0 & OUTPUT_B(x) doubt? |
Posted: Wed Feb 11, 2009 6:24 pm |
Hi, I have the next:
On PortB B0 is used for an external interrupt(Pull-up installed).
B1 to B7 to a 7 segments display.
I have made the next "declarations":
#use fast_io(b)
and in main:
set_tris_b( 0b00000001 );
After this, B0 is always input or can change at compile time????
I make this question because this: (tested)
When I output a value to the display on B0 (without making an interrupt intentionally) is 0V, when i do not display any value to the display the 5V back to B0.
For output the value is used: output_B(digit_p[n]);
So, when we set this on code( #use fast_io() and set_tris_x() ) the direction can change without "notification", or change??????
Thank“s on advance.
Note:
pic18f1320
display values : xxxxxxx0
ccs version 4.084 |
Posted: Wed Feb 11, 2009 7:00 pm |
Make a test program. Look at the .LST file.
| Code: | #include <18F1320.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use fast_io(b)
int8 digit_p[10];
int8 n;
It only changes the TRIS in the set_tris_b() statement, as shown in
bold below. This was compiled with vs. 4.084.
| Quote: |
.................... void main()
0004: CLRF TBLPTRU
0006: BCF RCON.IPEN
0008: CLRF FSR0H
000A: CLRF FSR0L
000C: BCF ADCON0.VCFG0
000E: BCF ADCON0.VCFG1
0010: MOVF ADCON1,W
0012: ANDLW 80
0014: IORLW 7F
0016: MOVWF ADCON1
.................... int8 digit_p[10];
.................... int8 n;
.................... set_tris_b( 0b00000001 );
0018: MOVLW 01
001A: MOVWF TRISB
.................... output_B(digit_p[n]);
001C: CLRF @03
001E: MOVF n,W
0020: ADDLW digit_p
0022: MOVWF FSR0L
0024: MOVLW digit_p+-6
0026: ADDWFC @03,W
0028: MOVWF FSR0H
002A: MOVFF INDF0,@@11
002E: MOVFF @@11,LATB
.................... while(1);
0032: BRA 0032
