Changing data type from float to ascii
Nora
PostPosted: Tue Feb 10, 2009 5:51 am     Reply with quote
hello-
Is there a command that changes the data type from float to ascii?
I am sending a float serially to a display with
printf("  PT = %3.2f",temp_f)
which results in printing PT = 85. If I ask the display to print this in HEX, it converts correctly PT = 0055
When I look at what is being sent via Hyperteminal, I see the correct value, which is constantly changing, but common values are something like 72.56, 73.45...
I think that it is possible that this display, a 4D systems OLED, cannot interpret this. I have only been able to get the display to correctly print
printf("U");
I have been able to get the display to send correct characters to my PIC18F452.
Therefore, I thought if I changed data types prior to sending, I might have better results.
Thank you,
Nora
SherpaDoug
PostPosted: Tue Feb 10, 2009 8:13 am     Reply with quote
Can you print text to this display? Beware of printing "U" as a test because that character may still print if it is inverted. Try other characters.
Printf by its nature converts its argument to an ASCII string sent out the serial port.
PostPosted: Tue Feb 10, 2009 1:39 pm     Reply with quote
interpret this.
Post the full OLED part number and a link to the web page for it.
Also post your PIC and your compiler version.
