starbuck
| A/D Converter on PIC16F886 |
Posted: Tue Feb 03, 2009 2:59 pm |
I am having a problem reading the internal AtoD converter on a PIC16F886. It appears when I look at the value in ADCON0 that the wrong input is being selected when I do a "set_adc_channel( x );"
I have looked at the 16F886.h file and it appears that I am using the correct constants to setup the ports and clock:
setup_adc_ports( sAN2 |sAN3 | sAN4 | VSS_VDD );
setup_adc( ADC_CLOCK_INTERNAL );
When I have selected look at ADCON0 it is set to a value of 0x11101001 (0xE9) which based on the PIC16F88x data sheet would indicate that I have selected AN10 not AN2 as I would expect.
Has anyone elese experienced this problem?
I am using PCM 4.085
Here is my source code:
| Code: | // ADC TEST
// Test code for PIC16F886 A to D Converter
// Compiler CCS PCM version 4.085
#include <16F886.H>
#device ICD = TRUE
#device *=16 ADC=10
#zero_ram
long AD_Ch_2 = 0;
long AD_Ch_3 = 0;
long AD_Ch_4 = 0;
// Setup PortA I/O
Set_Tris_A(0b011110); //sets up port A as an input port
//init A/D converter
set_adc_channel( PIN_A2 ); // ADC2 (RA2)
delay_us(10); // Delay to allow stabilization
AD_Ch_2 = read_adc(); // Get the AtoD value
set_adc_channel( PIN_A3 ); // ADC3 (RA3)
set_adc_channel( PIN_A4 ); // ADC4 (RA4)
Posted: Tue Feb 03, 2009 3:16 pm |
| Quote: | set_adc_channel( PIN_A2 );
set_adc_channel( PIN_A4 ); |
From the manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
| Quote: | Syntax: set_adc_channel (chan)
Parameters: 'chan' is the channel number to select.
Channel numbers start at 0 and are labeled in the data sheet AN0, AN1 |
ie., do not use Pin constants for channels. Use 0, 1, 2, 3, etc. for the
channel. |
starbuck
| OK - Read the Manual not just look at it! |
Posted: Tue Feb 03, 2009 3:44 pm |
Works fine, Thanks again PCM
Another case of staring at the manual too long!
Here is my revised code for the record:
// ADC TEST
#include <16F886.H>
#device ICD = TRUE
#device *=16 ADC=10
#zero_ram
long AD_Ch_2 = 0;
long AD_Ch_3 = 0;
long AD_Ch_4 = 0;
// Setup PortA I/O
set_adc_channel( 2 ); // ADC2 (RA2)
delay_us(20); // Delay to allow stabilization
set_adc_channel( 3 ); // ADC3 (RA3)
AD_Ch_3 = read_adc(); // Get the AtoD value
set_adc_channel( 4 ); // ADC4 (RA4)
AD_Ch_4 = read_adc(); // Get the AtoD value
