Keyboard, keypad debouncing and more
Hawk
PostPosted: Sun Jan 11, 2009 7:53 am     Reply with quote
Hello.
I've removed some parts from Mark's source code so it can fit my needs.
There is just single click check and hold down part.
I want to learn on this example but some help is welcome.
My end goal is to do keyboard (3x4, 4x4 debouncing on this way:
A B C a b c 1, A B C a b c 1, A B C a b c 1 and so on.
One button should be able to switch between this 7 possibilities and if you hold this button for 3 seconds, last char should be remembered.
The same as on mobile phones keypad.
Before i implement the keyboard i want to understand how to make this with the buttons on the picdem board , so i started with Mark's code.
1.) How to switch this possibilities thru some IF loop ?
2.) The clockspeed is 4 MHZ not 10 ( as in example ) so timer should be reconfigured.
Thank you.
case 0:
if (Switch_State[1] == SWITCH_HELD) // hold for 3 secounds
printf(lcd_putc,"\fSW1 Click\nWhile SW2 Held");
if ( )
printf(lcd_putc,"\fSW1 Click");
printf("A\n\r");
// Note to check timer2 setup if you change this to make sure it ints every ms
#define clockspeed 4000000
#use delay(clock=clockspeed)
#define CLICK_TIME        200       // Maximum time to consider a press/release a click
#define SWITCH_READ_TIME 30         // Interval to read the switches in ms
#define NUM_SWITCHES 2             // Good for up to 8 switches without having to modify the variable types
// Different types of click events
enum SWITCH_STATES
  SWITCH_IDLE,
  SWITCH_DOWN,
  SWITCH_HELD,                  // last char confirmation
  SINGLE_CLICK,
int8 Miliseconds;                  // Our system timer
int8 Read_Switch_Timer = 0;            // How often we read the switch inputs
int1 Read_Switch_Flag = FALSE;         // Signal to read the switches
int16 Click_Timer[NUM_SWITCHES];      // Timeout value or in this case the double click time
enum SWITCH_STATES Switch_State[NUM_SWITCHES];
// Timer 2 is our system tick
#int_timer2
void timer2_isr(void)
  if (Miliseconds < 0xFF)
    Miliseconds++;
// Handles what happens when we release a switch
void Switch_Released(int8 number)
  if (number < NUM_SWITCHES)      // Make sure this is a valid switch
    switch (Switch_State[number])
      case SWITCH_DOWN:          // Set the timer to the maximum time between a press and release to consider this a single click
        Click_Timer[number]  = CLICK_TIME;
        Switch_State[number] = SINGLE_CLICK;
      case SWITCH_HELD:          // Just set the timer to a small number so that it will fire as soon as we release the switch
        Click_Timer[number] = 1;   // Don't change the state here, the timers will take care of it
      case SINGLE_CLICK:           // Set the timer for the maximum time we will wait for a double click
      default:
        Click_Timer[number] = 0;
        Switch_State[number] = SWITCH_IDLE;
void Switch_Pressed(int8 number)   // Handles what happens when we press a switch
    if (Switch_State[number] == SWITCH_IDLE)  // Set the state to down only if we haven't just processed a click
        Switch_State[number] = SWITCH_DOWN;
void Switch_Read_Value(void)      // Handles debouncing of the switches
  static int8 last_read = 0xFF;
  static int8 last_state = 0xFF;
  static int8 debounce_count;
  int8 result = 0xFF;
  int8 i;
  int8 changed;
  if (!input(PIN_A4))             // Read the current result
    bit_clear(result,0);
  if (!input(PIN_B0))
    bit_clear(result,1);
  if (result != last_read)              // See if it changed
    // It did so debounce it
    debounce_count = 5;
    last_read = result;
  else if (debounce_count)             // We are debouncing
    debounce_count--;
    if (debounce_count == 0)           // Done debouncing
      changed = (result ^ last_state);   // See if the state of the switch has changed
      for(i=0;i<8;i++)                // Determine what type of event occurred
        if (bit_test(changed,i))
          if (bit_test(result,i))
            Switch_Released(i);
            Switch_Pressed(i);
            last_state = result;       // Save the current state
void Single_Click_Event(int8 number) // ***** ONE CLICK *****
  switch(number)                // TO ADD MORE SWITCHES you need to add the cases
    case 0:
        if (  )
      printf("A\n\r");
   case 1:
      if (Switch_State[0] == SWITCH_HELD)
        printf(lcd_putc,"\fSW2 Click\nWhile SW1 Held");
        printf(lcd_putc,"\fSW2 Click");
      printf("D\n\r");
   default:
void Switch_Timers(void)         // ***** Handles all our switch timers *****
  int8 i;
  if (Read_Switch_Timer == 0)
    Read_Switch_Timer--;
    Read_Switch_Flag = TRUE;
  for(i=0;i<NUM_SWITCHES;i++)
    if (Click_Timer[i])
      Click_Timer[i]--;
      if (Click_Timer[i] == 0)
        switch (Switch_State[i])
          case SWITCH_DOWN:
            Switch_State[i] = SWITCH_HELD;
          case SWITCH_HELD:
            Switch_State[i] = SWITCH_IDLE;
          case SINGLE_CLICK:
            Single_Click_Event(i);
          default:
void Switch_Tasks(void)         //***** Handles all our switch tasks *****
  if (Read_Switch_Flag)
    Switch_Read_Value();
    Read_Switch_Timer = SWITCH_READ_TIME;
//**** System counter *****
void System_Tick(void)
  while (Miliseconds)
    Switch_Timers();
    Miliseconds--;
PostPosted: Mon Jan 12, 2009 12:07 am     Reply with quote
Mark's code does not work with a 3x4 keypad. It's intended for individual
switches, where each switch is connected to a separate PIC pin.
You will need a different driver for a 3x4 keypad.
Here is a data sheet for Grayhill 3x4 keypads. They have switches
wired in a matrix and have a 7-pin header on the back:
http://embrace.grayhill.com/embrace/IMAGES/PDF/c-06-09.pdf
Hawk
PostPosted: Mon Jan 12, 2009 12:50 pm     Reply with quote
Hi PCM Programmer,
and thank you for reply.
Yes i am aware that Mark's code is for individual switches only, but i was thinking that maybe it would be interesting to implement this kind of logic into keypad.
How would you make this what i described in first post ?
I now i have to use timers but i am not quite sure how will all this affect performance of the program, speed etc.
Anyway, where would you start ?
John P
PostPosted: Mon Jan 12, 2009 5:06 pm     Reply with quote
Call me clueless, but what does "A B C a b c 1, A B C a b c 1, A B C a b c " mean?
PostPosted: Mon Jan 12, 2009 5:09 pm     Reply with quote
He wants it to cycle through the selections each time you push the button. First short push it displays A. the second short push it displays B etc. If you push and hold the button for three seconds it accepts that as the selection of the user.
Hawk
PostPosted: Sun Feb 01, 2009 6:05 am     Reply with quote
What is better way to connect the keypad, regarding to functionality described in previous posts ?
This
ht://i44.tinypic*com/1szblz.jpg
or
ht://i40.tinypic*com/rbxyrp.jpg
I will try to use modified ccs keypad example and mark's state machine idea, to get what i need. Suggestions, examples ?
Thanx!
