starbuck
| SPI Accelerometer (Freescale MMA7455L) and 16F886 |
Posted: Thu Jan 29, 2009 4:10 pm |
I am in the process of interfacing a Freeescale MMA7455L Three axis Digital Output Accelerometer to a PIC16F886. I am using the accelerometers SPI interface and the HW SPI Master of the PIC. I am having a problem reading data from the accelerometer. The accelerometer SDO line (MISO) stays low all the time. I have looked at the /CS, MOSI, and CK signals with a scope and they appear to be of the correct polarity and timing. I believe that I am sending the correct register and (R/W) bits to the device. Does anyone have experience with this device?
Note:
1) I am using CCS PCM version 4.085.
2) When I tried to use "#use spi( MASTER, MODE=0, MSB_FIRST, BITS=8, BAUD=5000, FORCE_HW )" to setup the spi port the CS had the wrong polarity for this device (CS = low), the CK and Data signals were out of phase and timing was not correct.
3) When I used " setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_64);" to setup the SPI port the signals were correct.
Here is my source code:
| Code: | // Test code for PIC16F886 connected to Freescale MMA745xL 3-axis Accelerometer
// Compiler CCS PCM version 4.085
#include <16F886.h>
#case
#device ICD = TRUE
#device *=16 ADC=8
#use delay ( clock = 20000000, restart_wdt )
//#use fast_io(a)
//#use fast_io(b)
//#use fast_io(c)
#fuses HS,WDT,NOPROTECT,BROWNOUT,PUT,NOLVP,NOCPD,NOWRT,NOCPD,NOIESO,NOFCMEN
// NOTE: THE #use SPI configuration below generated the wrong clock phase and the clock cycles wer not
// cooincidient with the data being clocked out on RC5 SDO.
//#use spi( MASTER, MODE=0, MSB_FIRST, BITS=8, BAUD=5000, FORCE_HW )
#zero_ram
int AccelX = 0, AccelY = 0, AccelZ = 0;
int Accel_Data = 0;
int Accel_Mode = 0;
// PORTS /////////////////////////////////////////////////////////////////
// PORTA 0b00000011 0x03
#define ULPWU_Cap PIN_A0 // PORT A0, pin 2, Ultra Low-Power Wake-Up Cap (Input)
#define Batt_Mon PIN_A1 // PORT A1, pin 3, Batt V Mon Analog (Input)
#define Mon_LED PIN_A2 // PORT A2, pin 4, Monitor LED (Output)
#define Servo_PWR PIN_A5 // PORT A5, pin 5, Servo Power Enable (Output)
#define Servo_PWM PIN_A4 // PORT A4, pin 6, Servo PWM (Output)
#define Bat_Mn_Ctrl PIN_A5 // PORT A5, pin 7, Battery Monitor Control (Output)
// PORTB 0b00110111 0x37
#define Acc_Int1 PIN_B0 // PORT B0, pin 21, Accelerometer Interrupt 1 (Input)
#define Rel_Pos_2 PIN_B1 // PORT B1, pin 22, Release Position Switch 2 (Input)
#define Rel_Pos_1 PIN_B2 // PORT B2, pin 23, Release Position Switch 1 (Input)
#define ICD_PGM PIN_B3 // PORT B3, pin 24, ICD RB3 Line
#define Acc_Int2 PIN_B4 // PORT B4, pin 25, Accelerometer Interrupt 2 (Input)
#define ARM_SW PIN_B5 // PORT B5, pin 26, Arming Pull Away Switch (Input)
#define ICD_PGC PIN_B6 // PORT B6, pin 27, ICD RB6 Line
#define ICD_PGD PIN_B7 // PORT B7, pin 28, ICD RB7 Line
// PORTC 0b00010100 0x14
#define Sonar_Trig PIN_C0 // PORT C0, pin 11, Sonar Strobe Pulse (Output)
#define Acc_CS PIN_C1 // PORT C1, pin 12, Accelerometer /CS (pin7 of MMA745xL)(Output)
#define Sonar_PW PIN_C2 // PORT C2, pin 13, Sonar Pulse Width (Input)
#define Acc_SCL PIN_C3 // PORT C3, pin 14, Accel (SPSCK) Serial Clock Out(SCL) (pin14 of MMA745xL)(Output)
#define Acc_MISO PIN_C4 // PORT C4, pin 15, Accel MasterInSlaveOut (MISO)(SDI) (pin12 of MMA745xL)(Input)
#define Acc_MOSI PIN_C5 // PORT C5, pin 16, Accel MasterOutSlaveIn (MOSI)(SDO) (pin13 of MMA745xL)(Output)
#define UNUSED_C6 PIN_C6 // PORT C6, pin 17, UNUSED
#define UNUSED_C7 PIN_C7 // PORT C7, pin 18, UNUSED
#define While_The_Sky_Is_Blue_And_The_Grass_Is_Green TRUE
#define HIGH 1
#define LOW 0
// Accelerometer SPI
// Freescale MMA7455L Accelerometer Defines
// api
#define XOUTL 0x00 // 10 bits output value X LSB
#define XOUTH 0x01 // 10 bits output value X MSB
#define YOUTL 0x02 // 10 bits output value Y LSB
#define YOUTH 0x03 // 10 bits output value Y MSB
#define ZOUTL 0x04 // 10 bits output value Z LSB
#define ZOUTH 0x05 // 10 bits output value Z MSB
#define XOUT8 0x06 // 8 bits output value X
#define YOUT8 0x07 // 8 bits output value Y
#define ZOUT8 0x08 // 8 bits output value Z
#define ASTATUS 0x09 // Status registers
#define DETSRC 0x0A // Detection source registers
#define TOUT 0x0B // Temperture out value
#define RES_0C 0x0C // Reserved 0x0C
#define I2CAD 0x0D // I2C device address
#define USRINF 0x0E // User information
#define WHOAMI 0x0F // Who am I value
#define XOFFL 0x10 // Offset drift x value (LSB)
#define XOFFH 0x11 // Offset drift x value (MSB)
#define YOFFL 0x12 // Offset drift y value (LSB)
#define YOFFH 0x13 // Offset drift y value (MSB)
#define ZOFFL 0x14 // Offset drift z value (LSB)
#define ZOFFH 0x15 // Offset drift z value (MSB)
#define MCTL 0x16 // Mode control
#define INTRST 0x17 // Interrupt latch reset
#define CTL1 0x18 // Control 1
#define CTL2 0x19 // Control 2
#define LDTH 0x1A // Level detection threshold limit value
#define PDTH 0x1B // Pulse detection limit value
#define PW 0x1C // Pulse duration value
#define LT 0x1D // Latency time value
#define TW 0x1E // Time windoe 2nd Pulse value.
#define RES_1F 0x1F // Reserved 0x1F
/************************ Function Prototypes ************************/
void initialize(void);
/************************* INITIALIZE *************************/
// Setup on-chip peripherals and i/o
void initialize(void) {
set_tris_a(0x03); // PortsA1 and A2 are a/d input, rest are digital outputs
set_tris_b(0xFF); // All B ports are inputs
set_tris_c(0x14); // C2 and C4 are Inputs, other pins are outputs
port_b_pullups(TRUE);
output_high(Acc_CS); // Deselect the accelerometer
output_low(Acc_SCL);
output_low(Acc_MOSI);
output_high(Mon_LED); // Turn the Monitor LED ON
restart_wdt();
} /* END void initialize (void) { */
/************************* MAIN *************************/
initialize();
delay_ms(50); // Power up delay to allow stabilization
while(While_The_Sky_Is_Blue_And_The_Grass_Is_Green) {
output_low(Acc_CS); // Select the accelerometer
spi_write((0x16<<1) | 0x80); // $16 Write to Mode Control Register
spi_write(0x05); // Make sure that we are in 4 wire SPI Mode(D5),
// using 2 G Range(D2&3(, and turned on(D0&1)
delay_us(10);
// output_low(Acc_CS); // Select the accelerometer
// spi_write( (0x0D<<1) | 0x80 ); // $0D Write to I2C Device Address Register
// spi_write( 0x9D ); // Disable I2C, keep address the same as default
// output_high(Acc_CS); // Deselect the accelerometer
// delay_us(10);
spi_write((0x16<<1) & 0x7f); // $16 Read Mode Control Register
Accel_Mode = spi_read(0); // $16 Read Mode Control Register
delay_us(80); // Long Interval for scope triggering (FD)
restart_wdt();
} /* END while(While_The_Sky_Is_Blue_And_The_Grass_Is_Green) */
} /* END main */ |
Posted: Thu Jan 29, 2009 7:32 pm |
I looked at the Freescale appnote, AN3468, and I made the test program
shown below. I also made it a lot more simple:
1. Don't use Fast i/o. It's not needed. Let the compiler set the TRIS.
2. Don't use the Watchdog. It's not needed in the initial test program.
3. Don't use the debugger. Display the output with RS-232 on a terminal
window.
4. Don't use inline code. Make the register r/w code into routines
which can be called (just like the appnote).
5. Follow all delay requirements. Add additional delay time for safety.
6. Use SPI defines, rather than CCS constants. The setup_spi()
statement then becomes self-documenting with respect to the mode.
7. The maximum SCLK frequency is 8 MHz for 3.3v operation of the
Freescale chip, so I used a clock divisor of 16, which gives 1.25 MHz.
I didn't use div64 because that seems excessive.
I didn't use defines for the register addresses or data, because at this
point I just wanted to follow the appnote closely.
#include <16F886.H>
#use delay(clock=20000000)
#define ACC_CS PIN_C1
// SPI modes
void Acc_Write_Register(int8 reg, int8 data)
output_low(ACC_CS);
spi_write(((reg & 0x3F) << 1) | 0x80);
spi_write(data);
output_high(ACC_CS);
int8 Acc_Read_Register(int8 reg)
int8 data;
output_low(ACC_CS);
spi_write((reg & 0x3F) << 1);
data = spi_read(0);
return(data);
int8 result;
int8 Xdata, Ydata, Zdata;
delay_ms(10); // Minimum 1 ms required after power-up.
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_16); // 1.25 MHz sclk
Acc_Write_Register(0x16, 0x05);
delay_ms(30); // Minimum 20 ms required after exiting standby
// Make sure we read back 0x05 from the Control register.
result = Acc_Read_Register(0x16);
printf("Control register = %X \n\r", result);
Xdata = Acc_Read_Register(0x06); //Read X,Y,Z outputs from Sensor
Ydata = Acc_Read_Register(0x07);
Zdata = Acc_Read_Register(0x08);
printf("XYZ: %U, %U, %U \n\r", Xdata, Ydata, Zdata);
starbuck
| Results of revised code |
Posted: Thu Jan 29, 2009 8:17 pm |
PCM Programmer,
I appreciate your insights into streamlining the code for debugging and FD as well as your taking the time to look at the device data sheet to make sure that I did not miss something important in the interface spec.
I tried your code on the hardware that I have here, incorporating your suggestion to use RS-232. That said the hardware, running your code, still is not outputting the MISO signal. I am beginning to think that I may have a bad accelerometer. I have additional devices on order and will replace the accelerometer once it arrives. |
wwwglro
Posted: Tue Aug 31, 2010 6:39 am |
Can you post the schematics?
Thank you |
wwwglro
Posted: Mon Oct 18, 2010 1:16 pm |
How can I use this accelerometer for g force aplications?
Thanks |
vascotech88
Joined: 10 Mar 2009 Posts: 33 Location: Aveiro, Portugal / Lodz, Polska
Posted: Mon Jan 17, 2011 8:42 am |
Hi all!
I am interfacing 3 accelerometers in SPI mode. I am having some problems, but i will test the code from PCM Programmer and check if it works here. Right now i am obtaining 0 for all axis _________________ -----
Vasco Jose Dias Baptista
http://vascotech88.pt.vu/ |
vascotech88
Posted: Mon Jan 17, 2011 3:28 pm |
Hello.
Now i was trying the code from PCM Programmer, but i have no results.
I changed a little bit but the result is around the same:
output_toggle(LED1);
printf("CTRL= %X, XYZ= %X, %X, %X \n\r", result, Xdata, Ydata, Zdata);
In the terminal window i obtain:
| Code: | * * * * * * * * * * COM Port Opened * * * * * * * * * *
Data received: CTRL= 3F, XYZ= 1F, 3F, 3F
Data received: CTRL= 3F, XYZ= 3F, 3F, 1F
Data received: CTRL= 1F, XYZ= 1F, 1F, 1F
Data received: CTRL= 3F, XYZ= 3F, 3F, 3F
Data received: CTRL= 3F, XYZ= 1F, 1F, 1F
Data received: CTRL= 3F, XYZ= 1F, 1F, 0F
Data received: CTRL= 3F, XYZ= 0F, 0F, 1F
Data received: CTRL= 3F, XYZ= 3F, 1F, 1F
Data received: CTRL= 1F, XYZ= 1F, 1F, 3F
Data received: CTRL= 1F, XYZ= 3F, 1F, 1F
Data received: CTRL= 1F, XYZ= 1F, 3F, 3F
Data received: CTRL= 3F, XYZ= 1F, 0F, 1F
Data received: CTRL= 1F, XYZ= 3F, 3F, 1F
Data received: CTRL= 1F, XYZ= 3F, 3F, 3F
Data received: CTRL= 1F, XYZ= 0F, 1F, 0F
Data received: CTRL= 3F, XYZ= 3F, 1F, 3F
Data received: CTRL= 1F, XYZ= 1F, 3F, 1F
* * * * * * * * * * COM Port Closed * * * * * * * * * * |
Any ideas to what is happening?? _________________ -----
vascotech88
Posted: Mon Jan 17, 2011 3:30 pm |
I forgot to tell:
| Code: | #include <16F872.h>
#device adc=8
#FUSES XT //Crystal osc <= 4mhz
#FUSES PUT //Power Up Timer
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
and on main:
| Code: | | setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_16); |
The rest is the same _________________ -----
Posted: Mon Jan 17, 2011 4:00 pm |
| Post a list of connections between the PIC and the MMA7455L. |
vascotech88
Posted: Mon Jan 17, 2011 4:47 pm |
Here are the schematics:
vascotech88
Posted: Mon Jan 17, 2011 4:48 pm |
SORRY!!!
The pins of the accelerometer are:
14-SCK
13-SDI
12-SDO _________________ -----
vascotech88
Posted: Mon Jan 17, 2011 4:51 pm |
I changed your code a little bit to add the 3 accelerometers:
| Code: | void accel_select(unsigned int8 n, unsigned int8 enable)
if(enable==1)
if(n==1) output_low(AC1);
else if(n==2) output_low(AC2);
else output_low(AC3);
if(n==1) output_high(AC1);
else if(n==2) output_high(AC2);
else output_high(AC3);
void Acc_Write_Register(int8 accel, int8 reg, int8 data)
accel_select(accel,1);
spi_write(data);
accel_select(accel,0);
int8 Acc_Read_Register(int8 accel, int8 reg)
int8 data;
data = spi_read(0);
return(data);
int8 result, i;
output_high(AC1);
output_high(AC2);
output_high(AC3);
output_low(LED1);
delay_ms(100); // Minimum 1 ms required after power-up.
for(i=1;i<4;i++)
Acc_Write_Register(i,0x16, 0x05);
result = Acc_Read_Register(i,0x16);
delay_ms(20);
Xdata = Acc_Read_Register(i,0x06); //Read X,Y,Z outputs from Sensor
delay_ms(20);
Ydata = Acc_Read_Register(i,0x07);
delay_ms(20);
Zdata = Acc_Read_Register(i,0x08);
printf("ACC=%U, CTRL=%X (05 exp), XYZ=%X,%X,%X \n\r", i, result, Xdata, Ydata, Zdata);
if(i==3) printf("\n\r");
And the results are (for different SPI speeds with 4MHz clock):
| Code: | DIV/4
ACC=1, CTRL=3F (05 exp), XYZ=3F,3F,1F
ACC=2, CTRL=3F (05 exp), XYZ=3F,3F,1F
ACC=3, CTRL=3F (05 exp), XYZ=3F,3F,1F
ACC=1, CTRL=1F (05 exp), XYZ=1F,1F,1F
ACC=2, CTRL=1F (05 exp), XYZ=1F,1F,1F
ACC=3, CTRL=3F (05 exp), XYZ=1F,3F,3F
ACC=1, CTRL=1F (05 exp), XYZ=3F,3F,3F
ACC=2, CTRL=3F (05 exp), XYZ=3F,3F,3F
ACC=3, CTRL=3F (05 exp), XYZ=3F,3F,3F
DIV/64
ACC=1, CTRL=00 (05 exp), XYZ=00,00,00
ACC=2, CTRL=00 (05 exp), XYZ=00,00,00
ACC=3, CTRL=00 (05 exp), XYZ=00,00,00
DIV/16
ACC=1, CTRL=7F (05 exp), XYZ=7F,7F,7F
ACC=2, CTRL=7F (05 exp), XYZ=7F,7F,7F
ACC=3, CTRL=7F (05 exp), XYZ=7F,7F,7F
Posted: Mon Jan 17, 2011 4:56 pm |
| What is the power supply voltage for the PIC, and for the MMA7455L ? |
vascotech88
Posted: Mon Jan 17, 2011 4:57 pm |
Damn... I have this project to do for wednesday and i am stuck in this...
I tried with the delays above, without, i checked all lines and its seems that i have all connections ok from the accelerometers to the PIC.
I am using USB 5V from my PC through a USB2TTL (serial) converter, and then on the board i use a 3.3V regulator, all the capacitors are according to the datasheets and the voltage is ~3.31V
The board was made at home, using laser printer method, soldered with solder paste in seringue and an oven with controlled temperature. All connections seems to be ok, the layout looked really very good before soldering, there are no short circuits.... Anyway, if there was problem with soldering it would not happen the same thing in the 3 accelerometers... _________________ -----
vascotech88
Posted: Mon Jan 17, 2011 5:00 pm |
Here is the picture of the board (this photo is older, because now it have 'through-hole' stuff soldered. But u can see the accelerometers and the smds
Is programmed by ICSP
