Programming problem
Lcj100
Programming problem
PostPosted: Tue Jan 13, 2009 6:47 pm     Reply with quote
I'm a final year student of BEE course. Currently I'm having problem with my final year project. I would like to get the example of source code about how to display the temperature value in seven segment display. I'm using CCS c compiler for my project........Anyone can help me? I need it urgently!!!!! thanks.
dyeatman
PostPosted: Tue Jan 13, 2009 8:17 pm     Reply with quote
If we give you the source code you ask for and you get your degree, what then? Are you going to get your colleagues to do all your work? If we do your project for you are you going to convey upon us your degree? The object of the project is for YOU to learn.
I would suggest that you try using the Search button on this forum before coming in pleading for us to bail you out. If you put in some effort the forum search should give you most of what you need....
Sorry to be so blunt but as an instructor, if I found one of my students in here trying to get someone else to complete their project with no effort invested on their part I would fail them on the spot.
