bertocar1974
| 18F4550 and int osc hangs with getc |
Posted: Sun Jan 11, 2009 4:28 am |
I'm trying to convert a project that i have developed for mikroc and that runs correctly in my board.
The problem i have is that getc() and kbhit() locks the execution.
I've tryed with interrupts too, but nothing changes.
Putc() sends correctly data.
The project runs perfectly with a mikroc version, so cannot be an hardware problem.
The oscillator is internal, 8Mhz.
This is the code:
(main.h)
| Code: | #include <18F4550.h>
#FUSES INTHS //Internal Oscillator, HS used by
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES NOMCLR //Master Clear pin enabled
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV1 //System Clock by 4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES NOVREGEN //USB voltage regulator enabled
#FUSES ICPRT //ICPRT enabled
#use delay(clock=8000000)
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS)
#use i2c(Master,Slow,I2C1)
(main.c)
#include "main.h"
#include <string.h>
#define VERSION "1.3.1"
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
char ch;
set_tris_a(0b00001110);
set_tris_b(0b10010100);
set_tris_c(0b11000100);
set_tris_d(0b00010000);
set_tris_e(0b00000000);
setup_spi(FALSE);
setup_adc_ports(AN0_TO_AN2|VSS_VDD);
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT);
setup_timer_1(T1_DISABLED);
disable_interrupts(GLOBAL);
setup_vref(FALSE);
enable_interrupts(INT_EXT2);
enable_interrupts(INT_RDA);
setup_oscillator(OSC_8MHZ|OSC_INTRC);
putc('#'); // this is ok
for (;;)
if (kbhit()) // << stops running
ch = getc();
putc(ch);
Can someone help me about the code?
Thanks,
Alberto |
Posted: Sun Jan 11, 2009 5:33 am |
The present code can't work, cause it enables interrupts without an interrupt service routine. This also doesn't make sense with any other C compiler, I suppose.
If global interrupts are disabled, this doesn't hurt, but then I don't see a reason for the observed behaviour. |
bertocar1974
Posted: Sun Jan 11, 2009 8:23 am |
I have extracted a part of the project.
The other compiler version is different, obviously.
Commenting out the interrupt enable parts, (if you have observed there is global interrupt set to off) nothing changes.
Thank you.
Alberto |
n-squared
Posted: Sun Jan 11, 2009 11:00 am |
Try commenting out the setup_oscillator() line.
My experience is that sometimes this function causes problems. _________________ Every solution has a problem. |
bertocar1974
Posted: Sun Jan 11, 2009 12:20 pm |
Thank you!
That is the problem, setting OSCCON manually resolved the problem.
Maybe a CCS bug?
Best regards,
Alberto |
