bkamen
Joined: 07 Jan 2004 Posts: 1616 Location: Central Illinois, USA
FYI: 18F26J11 no ECPLL #FUSE |
Posted: Sun Oct 17, 2010 11:47 am |
Just an FYI.
I informed CCS already -- but in case any of you think you're nuts. You're not.
Unless I'm nuts too. ;)
-Ben
ADDITIONAL: This adds another wrinkle since the PLL on the J11 is software enabled and when you give the HSPLL (or ECPLL) CCS inserts a OSCCON.PLLEN = 1 somewhere for you. Since I can't use the ECPLL (but can force is using #ROM), I have to put in my main to turn on the PLL otherwise other things (like #USE RS232) fall apart. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
