Integer Fast Math Library Using 8x8 Hardware Multiplier
OzanGazi
PostPosted: Fri Jan 02, 2009 6:37 am     Reply with quote
Hi all!!
in the past i was composed a fast math library for realtime RMS measurement. Now i recomposed the Library for CCS forum users.
These are functions and calculation times on 40Mhz clock...
res16=fast_SquareRoot(val32); calculation time ~105uS
res32=fast_Square(val16); calculation time ~6 uS
res32=fast_Divide32by16(val32,val16); calculation time ~60uS
res32=fast_Multiply16by16(val16,val16); calculation time ~6 uS
Code edited.. on Fri Jan 02, 2009 7:00 am
//                             fastmath.c                            //
//   Integer Fast Operations Library Using 8x8 Hardware Multiplier   //
//                This Code composed by OzaNGazi                     //
//     0x010-0x01B RAM area is allocated for using asm functions     //
//     !!   Hardware Mutliplier Registers must be defined   !!       //
//          (e.g. pic18f452)                                         //
//          #byte PRODL=0xFF3                                        //
//          #byte PRODH=0xFF4                                        //
//                           Functions                               //
//    res16=fast_SquareRoot(val32);      //calculation time ~105 uS  //
//    res32=fast_Square(val16);          //calculation time ~6 uS    //
//    res32=fast_Divide32by16(val32);    //calculation time ~60uS    //
//    res32=fast_Multiply16by16(val16); //calculation time ~6 uS    //
unsigned long fast_SquareRoot(unsigned long long kok_girdi_);
unsigned long long fast_Square(unsigned long kare_girdi_);
unsigned long long int fast_Divide32by16(unsigned long long int Dividend_ , unsigned long int Divisor_ );
Unsigned Long long int fast_Multiply16by16(unsigned long int mul1 , unsigned long int mul2) ;
   unsigned long long Kare_Sonuc;
   #locate Kare_Sonuc = 0x010
   #Byte SQRES0 = 0x010
   #Byte SQRES1 = 0x011
   #Byte SQRES2 = 0x012
   #Byte SQRES3 = 0x013
   unsigned long Kare_Girdi;
   #locate Kare_Girdi = 0x014
   #Byte ARG1L = 0x014
   #Byte ARG1H = 0x015
   kare_girdi=kare_girdi_;
   #asm
   ; *********** 16 X 16 Unsigned Square *****************************
   ; SQRES3:SQRES0 = ARG1H:ARG1L ^2
Sq16:
   movf ARG1L, W
   mulwf ARG1L ; ARG1L * ARG2L ->
   ; PRODH:PRODL
   movff PRODH, SQRES1 ;
   movff PRODL, SQRES0 ;
   movf ARG1H, W
   mulwf ARG1H ; ARG1H * ARG2H ->
   ; PRODH:PRODL
   movff PRODH, SQRES3 ;
   movff PRODL, SQRES2 ;
   movf ARG1L, W
   mulwf ARG1H ; ARG1L * ARG2H ->
   ; PRODH:PRODL
   movf PRODL, W ;
   addwf SQRES1, F ; Add cross
   movf PRODH, W ; products
   addwfc SQRES2, F ;
   clrf WREG ;
   addwfc SQRES3, F ;
   movf ARG1H, W ;
   mulwf ARG1L ; ARG1H * ARG2L ->
   ; PRODH:PRODL
   movf PRODL, W ;
   addwfc SQRES2, F ;
   clrf WREG ;
   addwfc SQRES3, F ;
   #endasm
   return(Kare_Sonuc);
     unsigned long long Kok_Girdi;
     unsigned long Kok_Sonuc;
     #Byte ARG1L = 0x014
     #Byte ARG1H = 0x015
     #locate Kok_Girdi = 0x016
     #Byte ARGA0 = 0x016
     #Byte ARGA1 = 0x017
     #Byte ARGA2 = 0x018
     #Byte ARGA3 = 0x019
     #locate Kok_Sonuc = 0x01A
     #Byte RES0 = 0x01A
     #Byte RES1 = 0x01B
     unsigned int temp0,temp1,bitloc0,bitloc1;
     kok_girdi=kok_girdi_;
     #asm
square:
   ; ******************** Square Root **********************************
   ; Sqrt32(ARGA3:ARGA2:ARGA1:ARGA0) = RES1:RES0
Sqrt32:
   clrf TEMP0 ; clear the temp solution
   clrf TEMP1
   clrf BITLOC0 ; setup the first bit
   clrf RES0
   movlw 0x80
   movwf BITLOC1 ; BitLoc = 0x8000
   movwf RES1 ; RES = 0x8000
Squar16:
   movff RES0, ARG1L ; square the guess
   movff RES1, ARG1H
   call Sq16
   movf SQRES0, W ; ARGA - PROD test
   subwf ARGA0, W
   movf SQRES1, W
   subwfb ARGA1, W
   movf SQRES2, W
   subwfb ARGA2, W
   movf SQRES3, W
   subwfb ARGA3, W
   btfsc STATUS,0
   bra NxtBt16 ; if positive then next bit
   ; if negative then rotate right
   addlw 0x00 ; clear carry
   movff TEMP0, RES0 ; move last good value back into RES0
   movff TEMP1, RES1
   rrcf BITLOC1, F ; then rotote the bit and put it
   rrcf BITLOC0, F
   movf BITLOC1, W ; back into RES1:RES0
   iorwf RES1, F
   movf BITLOC0, W
   iorwf RES0, F
   btfsc STATUS, 0 ; if last value was tested then get
   bra Done32 ; out
   bra Squar16 ; elso go back for another test
NxtBt16:
   movff RES0, TEMP0 ; copy the last good approximation
   movff RES1, TEMP1
   rrcf BITLOC1, F ; rotate the bit location register
   rrcf BITLOC0, F
   movf BITLOC1, W ; and put back into RES1:RES0
   iorwf RES1, F
   movf BITLOC0, W
   iorwf RES0, F
   bra Done32 ; out
   bra Squar16
Done32:
   movff TEMP0,RES0 ; put the final result in RES1:RES0
   movff TEMP1,RES1
   bra over
Sq16:
   movf ARG1L, W
   ; PRODH:PRODL
   movf ARG1H, W
   ; PRODH:PRODL
   movf ARG1L, W
   ; PRODH:PRODL
   movf PRODL, W ;
   addwfc SQRES2, F ;
   clrf WREG ;
   addwfc SQRES3, F ;
   movf ARG1H, W ;
   ; PRODH:PRODL
   movf PRODL, W ;
   addwfc SQRES2, F ;
   clrf WREG ;
   addwfc SQRES3, F ;
   return
over:
   #endasm
   return(kok_sonuc);
Unsigned Long long int Fast_Divide32by16(unsigned long long int Dividend_ , unsigned long int Divisor_ )
   unsigned int bitcnt;
   unsigned Long long int Dividend;
   #locate dividend =0x010
   #byte divid0 =0x010
   #byte divid1 =0x011
   #byte divid2 =0x012
   #byte divid3 =0x013
   unsigned long int Divisor;
   #locate Divisor =0x014
   #byte DivisL =0x014
   #byte DivisH =0x015
   unsigned long int Remdr;
   #locate Remdr =0x016
   #byte RemdrL =0x016
   #byte RemdrH =0x017
   Dividend=Dividend_;
   Divisor=Divisor_;
     #asm
divide:
   movlw 0x20      ; 32-bit divide by 16-bit
   movwf bitcnt
   clrf remdrH   ; Clear remainder
   clrf remdrL
dvloop:
       bcf STATUS,0          ; Set quotient bit to 0
                     ; Shift left dividend and quotient
       rlcf divid0,f    ; lsb
       rlcf divid1,f
       rlcf divid2,f
       rlcf divid3,f    ; lsb into carry
       rlcf remdrL,f    ; and then into partial remainder
       rlcf remdrH,f
       btfsc STATUS,0         ; Check for overflow
       goto subd
       movf divisH,W  ; Compare partial remainder and divisor
       subwf remdrH,w
       btfss STATUS,2
       goto testgt   ; Not equal so test if remdrH is greater
       movf divisL,W  ; High bytes are equal, compare low bytes
       subwf remdrL,w
testgt:
       btfss STATUS,0          ; Carry set if remdr >= divis
       goto remrlt
subd:
       movf divisL,W  ; Subtract divisor from partial remainder
       subwf remdrL
       btfss STATUS,0           ; Test for borrow
       decf remdrH   ; Subtract borrow
       movf divisH,w
       subwf remdrH
       bsf divid0,0  ; Set quotient bit to 1
                     ; Quotient replaces dividend which is lost
remrlt:
       decfsz bitcnt
       goto dvloop
     #endasm
     return(dividend);
Unsigned Long long int Fast_Multiply16by16(unsigned long int mul1_ , unsigned long int mul2_)
   unsigned long int wrd;
   unsigned long int luk;
   unsigned long long int res;
   unsigned int C3;
   #locate res = 0x010
   #locate wrd = 0x010
   #Byte wrd_L = 0x010
   #Byte wrd_H = 0x011
   #locate ext = 0x012
   #Byte ext_L = 0x012
   #Byte ext_H = 0x013
   #locate luk = 0x014
   #Byte luk_L = 0x014
   #Byte luk_H = 0x015
   wrd=mul1_;
   luk=mul2_;
   #asm
;Multiplication 16bit * 16bit -> 32bit
;WRD * LUK -> EXTWRD
;detailed: WRD_H:WRD_L * LUK_H:LUK_L -> EXT_H:EXT_L:WRD_H:WRD_L
;LUK value remains. Affected registers: temp reg C3
MULW:  movf    WRD_H,w
       mulwf   LUK_H    ; LUK_H * WRD_H
       movff   PRODH,EXT_H
       movff   PRODL,EXT_L
       movf    WRD_L,w
       mulwf   LUK_L    ; LUK_L * WRD_L
       movff   PRODH,C3
       movff   PRODL,WRD_L
       mulwf   LUK_H    ; LUK_H * WRD_L
       movf    PRODL,w
       addwf   C3,f    ; Add cross
       movf    PRODH,w    ; products
       addwfc  EXT_L,f
       clrf    WREG
       addwfc  EXT_H,f
       movf    WRD_H,w
       mulwf   LUK_L    ; LUK_L * WRD_H
       movf    PRODL,w    ;
       addwf   C3,w    ; Add cross
       movwf   WRD_H
       addwfc  EXT_L,f
       clrf    WREG
       addwfc  EXT_H,f
#endasm
   return(res);
