Don P
| syntax of Shift & Rotate ? |
Posted: Sun Dec 21, 2008 5:08 pm |
I'm having little luck making the shift & rotate left & right functions work.
In particular, I declare int x[3], and set them to some arbitrary values.
Rotate_Right (as I read it) should take Rotate_Right( &x, 4 ).
First, it won't take &x. I have to specify a variable, so I try &x[0].
But my rotates don't work as expected, e.g.:
| Code: | x[0]=0x0F;
x[1]=0x00;
x[2]=0x03;
x[3]=0x07;
rotate_right( &x[0], 4 ) ;
printf("%X,%X,%X,%X",x[0],x[1],x[2],x[3]) ; |
I see values: 07,80,81,83
So where did x[2] get a value of 81 from;
and where did the LSB of x[3] disappear to?
Similar weirdness for the other functions.
TIA
Don |
Posted: Sun Dec 21, 2008 6:07 pm |
It's correct.
I would have displayed it like this, with the MSB first:
| Code: | | printf("%X,%X,%X,%X",x[3], x[2], x[1], x[0]) ; |
A 32-bit word is stored in Intel "Lo-Hi" format. The lowest byte is
stored first in memory. The highest byte is stored in the highest
address.
So, the 32-bit value you are starting with is:
If that value is rotated right by 1 bit position, you will get:
Compare the initial and resulting values in binary:
00000111 00000011 00000000 00001111
10000011 10000001 10000000 00000111 |
The lower value is rotated right by 1 bit postion from the upper value. |
Wayne_
Posted: Mon Dec 22, 2008 3:22 am |
I have to disagree with your statement PCM programmer.
If he were storing the value in a 32bit int
int32 a;
a = 0x0F000307;
rotate_right( &a, 4 ) ;
Then yes, the fact that it is a 32bit int matters. But he is using an array and manually placing the values in the correct place. Unless CCS stores array values in reverse order then his code should work
The data at x is
0x0F 0x00 0x03 0x07
00001111 00000000 00000011 00000111
Rotated right by 1
10000111 10000000 00000001 10000011
0x87 0x80 0x01 0x83
There are actually 2 bit errors so it looks like the carry bit is placed in at the wrong point.
It is unfortunate that the values being used follow what you have said PCM but the fact still remains that and array is being used not an int declaration.
Don P should check the lst file to see what it is doing!
Also you could try
rotate_right(x, 4);
Because x is an array by specifying the letter you are refering to the address of the array. |
Posted: Mon Dec 22, 2008 3:27 am |
Several other little comments.
In 'C', the name of an array _on it's own,is_ a shortcut syntax, fo the address of the array. So with x[n],
x is the address of the array
&x[0] also equals the address of the array
&x, would attempt to find the address of the address. Since the address is not actually 'stored', this is illegal.
Next comment. You declare int x[3], then are using _4_ in the second byte of the rotate instruction. This means you are going to potentially destroy the variable held in the next memory location. You have declared the array as _3_ bytes long, wih locations x[0], x[1], and x[2], then start accessing x[3].... In C, the declaration is for the size of the array (hence 3 bytes), and the indexes allowed, are zero, to the size-1. You need int x[4].
This invalid layout, is probably what is causing the behaviour to not be 'as expected'.
Wayne_
Posted: Mon Dec 22, 2008 4:19 am |
Well spotted Ttelmah, missed the array size issue  |
