rajshek_2010
| PIC J Series Issue with PLL |
Posted: Tue Dec 16, 2008 8:48 am |
I have recently upgraded my compiler to support J Series.
The current compiler version is 4.083.
We are using PIC18F65J11 with 10 MHz crystal. We wanted to use 4 x PLL clock multiplier.
When we try debugging the debug windows shows that micro is working in 10MHz while we have configured for 10 MHz x 4 PLL.
When we tried PIC18F8722 with 10 MHz, it works well with compiler. The debug window shows as 40 MHz.
Can someone help?
| Code: | #include <18F65J11.h>
#device ICD=TRUE
#device adc=8
#FUSES H4_SW //High speed osc with SW enabled 4x PLL
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES PRIMARY //Primary clock is system clock when scs=00
#use delay(clock=10000000)
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// TODO: USER CODE!!
output_high(PIN_B1); delay_ms(1000);
output_low(PIN_B1);delay_ms(1000);
asmallri
Joined: 12 Aug 2004 Posts: 1670 Location: Perth, Australia
Posted: Tue Dec 16, 2008 9:33 am |
You did not use the correct value for the delay parameter
| Code: | | #use delay(clock=10000000) |
should be
| Code: | | #use delay(clock=40000000) |
_________________ Regards, Andrew
