PIC J Series Issue with PLL
rajshek_2010
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Tue Dec 16, 2008 8:48 am     Reply with quote
I have recently upgraded my compiler to support J Series.
The current compiler version is 4.083.
We are using PIC18F65J11 with 10 MHz crystal. We wanted to use 4 x PLL clock multiplier.
When we try debugging the debug windows shows that micro is working in 10MHz while we have configured for 10 MHz x 4 PLL.
When we tried PIC18F8722 with 10 MHz, it works well with compiler. The debug window shows as 40 MHz.
Can someone help?
#include <18F65J11.h>
#device ICD=TRUE
#device adc=8
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES H4_SW                    //High speed osc with SW enabled 4x PLL
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOSTVREN                 //Stack full/underflow will not cause reset
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES PRIMARY                  //Primary clock is system clock when scs=00
#use delay(clock=10000000)
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   // TODO: USER CODE!!
      output_high(PIN_B1); delay_ms(1000);
      output_low(PIN_B1);delay_ms(1000);
asmallri
PostPosted: Tue Dec 16, 2008 9:33 am     Reply with quote
You did not use the correct value for the delay parameter
should be
#use delay(clock=40000000)
Regards, Andrew
