Setup Timer1 on PIC16F687
boulder
PostPosted: Mon Dec 08, 2008 7:55 pm     Reply with quote
I want to have a increment of 1 from 0 to 9 every 500ms and display the number on a 7_segment_led, but increment is never happened. The below is my code could you help me to find out what's wrong with it?
Thanks!
#include <16F687.h>
#use delay(clock=3686400, crystal)
#use rs232(baud=115200, xmit=PIN_B7, rcv=PIN_B5)
#fuses XT, NOWDT, PUT, MCLR, NOPROTECT, NOCPD, NOBROWNOUT, NOIESO, NOFCMEN
volatile unsigned int8 i=0;
#INT_TIMER1
void TIMER1_ISR()
    i++;
    if(i > 9)
      i = 0;
  setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H SPI_CLK_DIV_16);   //Setup SPI interface, mode 0
  set_timer1(0x1F00);      //1 interrupt every 500ms
  setup_timer_1(T1_EXTERNAL | T1_CLK_OUT | T1_DIV_BY_8);
  enable_interrupts(global);
    Display_i_to_led();
PostPosted: Mon Dec 08, 2008 8:40 pm     Reply with quote
Use T1_INTERNAL instead of the parameters in bold.
boulder
PostPosted: Mon Dec 08, 2008 9:01 pm     Reply with quote
Yes, it works with the internal clock, 8MHz. Why it does not work with external clock? In my PCB, this chip is connected to an external clock, 3866400 Hz, on purpose for UART baudrate 115200. Are there any methods to make timer1 work with this external clock?
Thanks.
PostPosted: Mon Dec 08, 2008 9:16 pm     Reply with quote
You are not using the internal oscillator at 8 MHz. You are using the
crystal oscillator (XT) at 3.6864 MHz.
boulder
PostPosted: Mon Dec 08, 2008 9:22 pm     Reply with quote
Yes, I am using internal clock. I already changed clocked after your first reply from
to
#use delay(clock=8000000)
I don't understand why external clock does not work. Do you have any explanation for it?
Thanks!!!
boulder
PostPosted: Mon Dec 08, 2008 9:40 pm     Reply with quote
I realize that if I use external clock
But Timer1 setup use INTERNAL
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
it works too. Why?
Thanks.
PostPosted: Mon Dec 08, 2008 9:54 pm     Reply with quote
T1_INTERNAL uses the crystal frequency, divided by 4.
PostPosted: Mon Dec 08, 2008 9:57 pm     Reply with quote
You can't run the Timer1 oscillator at 3.6864 MHz. Look in the 16F687
data sheet, on page 246 (page 248 in the Acrobat reader):
http://ww1.microchip.com/downloads/en/DeviceDoc/41262E.pdf
It shows that the typical frequency for the Timer1 oscillator is only
32.768 KHz. An older revision of the data sheet lists 200 KHz as the
maximum allowable frequency. You can't run it with a 3.6864 MHz
crystal.
boulder
PostPosted: Mon Dec 08, 2008 10:30 pm     Reply with quote
Is it Okay for me to use both 3686400Hz and T1_INTERNAL and in my project? Because I need this external crystal for baudrate 115200, also it works fine for Timer1 with T1_INTERNAL.
Thanks!!!!
PostPosted: Mon Dec 08, 2008 10:34 pm     Reply with quote
That is the standard way of doing it.
