PIC16F873A with LCD 16x4
Goto page Previous  1, 2
PostPosted: Mon Nov 17, 2008 2:23 pm     Reply with quote
That's the same controller that is used in the CrystalFontz LCD that
I used to test the Flex driver. So, the Flex driver should work with
your LCD.
Did you buy this LCD new ? Or is it a used LCD from EBay ?
The main reason for black squares is that the connections are not
correct, or maybe a wire is broken, or a solder joint is bad, etc.
Carefully check all connections. Make sure the list of #define
statements matches the actual connections.
deniska_gus
PostPosted: Mon Nov 17, 2008 2:31 pm     Reply with quote
I took this LCD from our store. I work in an electronic company. It is new. Ok, I will check all connections. Thank you very much
deniska_gus
PostPosted: Tue Nov 18, 2008 12:02 pm     Reply with quote
PCM programmer, thank you very much. It is working! A DB1 wire was broken.
Page 2 of 2
