16F88 I2C master slave problem
ymoona
PostPosted: Thu Nov 13, 2008 3:17 pm     Reply with quote
I'm using two 16F88 to communicate via i2c.
The master is reading two bytes, the slave is writing two bytes.
I'm using version 4.013.
This is the master code
#include <16F88.h>
#device *=16
#device adc=10
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES PUT                    //No Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#use delay(clock=8000000)
#use rs232(baud=19200,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8)
#use i2c(Master,sda=PIN_B1,scl=PIN_B4)
int8 address;
#int_RDA
RDA_isr()
   char c;
   c = getc();
   putc( c );
#define LED_RED PIN_A4
#define LED_YELLOW PIN_A3
#define LED_GREEN PIN_A2
#define SLAVE 0xA0
   int byte1, byte2;
   setup_adc_ports(sAN0|VSS_VDD);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_16,2,4);
   setup_vref(FALSE);
   enable_interrupts(INT_RDA);
   setup_oscillator(OSC_8MHZ);
   delay_ms( 100 );
   printf("\f");
   while(1){
      output_high( LED_GREEN );
      delay_ms( 500 );
      output_low( LED_GREEN );
      delay_ms( 500 );
      i2c_start();
      putc('S');
      i2c_write(SLAVE + 1);
      putc('W');
      byte1 = i2c_read();
      putc('R');
      byte2 = i2c_read(0);
      putc('R');
      i2c_stop();
      putc('T');
      printf( " byte1=%02x, byte2=%02x\n\r" , byte1, byte2 );
Why MUST the second i2c_read be called with an argument 0? If I dont do that the master will hang.
This is the slave code
#include <16F88.h>
#device *=16
#device adc=10
#FUSES NOMCLR                     //Master Clear pin enabled
#use i2c(Slave,sda=PIN_B1,scl=PIN_B4,address=0xA0)
#int_RDA
RDA_isr()
   char c;
   c = getc();
   putc( c );
unsigned int incomming = 0, state;
#int_SSP
SSP_isr()
  //putc('.');
   state = i2c_isr_state();
   if( state < 0x80)
   if(state >= 0x80)
      if(state == 0x80){
         OUTPUT_TOGGLE( LED_GREEN );
         putc('1');
         i2c_write(0x56);
      else if(state == 0x81){
         OUTPUT_TOGGLE( LED_YELLOW );
         i2c_write(0x1F);
         putc('2');
      else if(state == 0x82){
        OUTPUT_TOGGLE( LED_RED );
        i2c_write(0x45);
        putc('3');
   setup_vref(FALSE);
   enable_interrupts(INT_SSP);
   printf("\f");
   while(1){
      delay_ms( 1000 );
Now the data is read fine, but in the terminal of the slave I see on every read action of the master "123". Also the three leds toggle. Indicating to
me that 3 bytes are read.
When I put a putc('.'); in the beginning of the ISR I get ".1.2" in the terminal of the slave. Indicating to me that only two bytes are read.
What am I doing wrong, can
checkout my site: www.ymoona.com/wiki
PostPosted: Thu Nov 13, 2008 3:29 pm     Reply with quote
It's part of the i2c specification. You can download it here:
http://www.nxp.com/acrobat_download/literature/9398/39340011.pdf
Look in this section, on the right side of the page:
7.2 Acknowledge
It says what an i2c master must do when it's clocking bytes out of
the slave:
If a master-receiver is involved in a transfer, it must signal
the end of data to the slave-transmitter by not generating
an acknowledge on the last byte that was clocked out of
the slave. The slave-transmitter must release the data line
to allow the master to generate a STOP or repeated
START condition.
In CCS, a "not acknowledge" is generated by using a 0 parameter
in the i2c_read() statement.
ymoona
PostPosted: Thu Nov 13, 2008 3:42 pm     Reply with quote
Thanks, that makes sense.
Do you also have an answer to my other questions?
