Fram_fr
| Driver for GU112x16_7806 Noritake Itron VFD display |
Posted: Thu Nov 06, 2008 5:22 am |
Hi all,
here is a driver which contains a set of useful routines for use with a Noritake-Itron GU112X16-7806 graphical Vacuum Fluorescent Display (VFD)in parallel interface.
// File: VFD_GU112x16_7806.c
// Purpose: Graphical VFD routines.
// Description: This file contains a set of useful routines for use with
// a Noritake-Itron GU112X16-7806 graphical Vacuum Fluorescent
// Display (VFD)in parallel interface.
#define set_tris_lcd(x) set_tris_d(x) //port D used for DATA D0 to D7
// BRIGHTNESS LEVEL - According to datasheet to configure VFD brightness
#DEFINE brightness_25 0x03
#DEFINE brightness_50 0x02
#DEFINE brightness_75 0x01
#DEFINE brightness_100 0x00
// write a byte to the VFD cmd register
void vfd_write_cmd(unsigned char c)
unsigned char busy;
set_tris_lcd(0xff); // set data port to input
output_high(VFD_RW); // read
output_low(VFD_RS);
do {
output_high(VFD_EN);
busy = (input_d() & 0x80);
output_low(VFD_EN);
} while (busy);
set_tris_lcd(0x00); // set data port to output
output_low(VFD_RW); // write
output_low(VFD_RS);
output_d(c);
output_low(VFD_EN);
// write a byte to the VFD data register
void vfd_write_data(unsigned char c)
unsigned char busy;
output_low(VFD_RS);
do {
output_low(VFD_EN);
} while (busy);
output_high(VFD_RS);
output_d(c);
output_low(VFD_EN);
// Clear and home the LCD
void vfd_clear()
vfd_write_cmd(0x01);
delay_ms (10);
// Cursor return home
void vfd_cursor_home()
vfd_write_cmd(0x02);
delay_ms (10);
// initialise the VFD - put into 8 bit mode
void vfd_init(unsigned char brightness)
output_low(VFD_EN);
vfd_write_cmd (0x30);
delay_ms (10);
delay_ms (10);
delay_ms (10);
vfd_write_cmd (0x30); // Eight bit mode
delay_ms (10);
vfd_write_data(brightness); // Set luminance
vfd_write_cmd(0x06);
vfd_write_cmd(0x0c);
vfd_clear(); // Clear screen
// Set luminance of the VFD
void vfd_set_brightness(unsigned char brightness)
output_low(VFD_EN);
vfd_write_data(brightness); // Set luminance=75%
// Set the VFD font
// 'A' 4x6 mini font
// 'B' 5x7 Katakana font
// 'C' 10x14 Katakana font
// 'b' 5x7 European font
// 'c' 10x14 European font
// '1' 1 pixel inter-character spacing
// '2' 2 pixel inter-character spacing
void vfd_font(unsigned char font)
vfd_write_cmd(0xf2);
vfd_write_data(font);
void vfd_font_small()
vfd_font('1');
vfd_font('A');
void vfd_font_medium()
vfd_font('1');
vfd_font('b');
void vfd_font_large()
vfd_font('2');
vfd_font('c');
// write a string of chars to the VFD
void vfd_puts(unsigned char text)
vfd_write_data(text);
// Go to the specified position
// xpos = 0-111, ypos = 0-15
void vfd_goto(unsigned char xpos, unsigned char ypos)
vfd_write_cmd(0xf0);
vfd_write_data(xpos);
vfd_write_data(ypos);
delay_us(1);
// Set the VFD area
// x1, y1 = left top of area
// x2, y2 = right bottom of area
// Commands:
// 'I' Invert area
// 'F' Fill area
// 'C' Clear area
// 'O' Set outline
// 'o' Clear outline
// 'H' Write horizontal graphical data with horizontal cursor movement
// 'V' Write vertical graphical data with vertical cursor movement
// 'h' Write horizontal graphical data with vertical cursor movement
// 'v' Write vertical graphical data with horizontal cursor movement
void vfd_area(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, unsigned char cmd)
vfd_write_cmd(0xf1);
vfd_write_data(x1);
vfd_write_data(y1);
vfd_write_data(x2);
vfd_write_data(y2);
vfd_write_data(cmd);
// display shift of "count" positions to the right
void vfd_shift_right(unsigned char count) // low speed shift
int i;
for (i=0; i<=count; i++)
vfd_write_cmd(0x1C);
delay_ms(30);
void vfd_shift_right2(unsigned char count) // normal speed shift
int i;
delay_ms(20);
void vfd_shift_right3(unsigned char count) // high speed shift
int i;
delay_ms(10);
// display shift of "count" positions to the left
void vfd_shift_left(unsigned char count) // low speed shift
int i;
vfd_write_cmd(0x18);
delay_ms(30);
void vfd_shift_left2(unsigned char count) // normal speed shift
int i;
delay_ms(20);
void vfd_shift_left3(unsigned char count) // high speed shift
int i;
delay_ms(10);
// enable or disable the display
// * 0 = disable, 1 = enable
void vfd_display_control(unsigned char on_off)
vfd_write_cmd(0x0F);
vfd_write_data(on_off);
// enable or disable the flashing bloc cursor
void vfd_display_cursor(unsigned char cursor)
vfd_write_cmd(0x08);
vfd_write_data(cursor);
