Sleep mode and startup... |
Posted: Sat Sep 27, 2008 3:14 pm |
Hi
The PIC is a 2455.
I use timer1 as RTC no problem it's running.
When no key is pressed for 1 min. the PIC must go to sleep mode, it's working.
The last instruction before Sleep();
bit_set(OSCCON,0);
bit_clear(OSCCON,1);
bit_set(OSCCON,7);
SleepMode=true;
Sleep();
Just for you to see what OSCCON is...
Code: | #byte OSCCON = 0xFD3 |
The only way I can get it out of sleep is a reset_cpu.
#INT_RB
void PortBChange(void)
if (!input(_sw1) && (SleepMode)) { reset_cpu(); }
It's not nice!
The Timer1 my RTC clock must run when PIC is sleeping I think it's working.
Is there another way? Because when resetting all the user data is cleared because the program counter is at powered first time.
[/quote] |
FvM
Posted: Sat Sep 27, 2008 4:54 pm |
Quote: | The Timer1 my RTC clock must run when PIC is sleeping I think it's working. |
No. Cause all oscillators are stopped in sleep mode, timer1 is not working. SEC_IDLE rather than SLEEP would be an appropriate mode. In SLEEP, WDT is the only available option for a timed wakeup.
You didn't exactly tell, what you are trying to achieve, but I guess you want to use Timer1 for wakeup.
Regards,
Frank |
Posted: Sun Sep 28, 2008 12:13 am |
Hi
Hmmm. Are there any other hints for getting out of the sleep.
Before sleeping I set. This is Timer1 run but main "cpu" does not.
Code: | bit_set(OSCCON,0);
bit_set(OSCCON,7);
After 1 min. get to sleep.
When something change on port B and in sleep reset the cpu.
This is working.
The q is: How to still run Timer1 and wake up the pic at the same point as when it go to sleep?? |
FvM
Posted: Sun Sep 28, 2008 2:17 am |
I didn't realize, that you already set OSCON to SEC_IDLE instead of SLEEP. Thus Timer1 should continue to work and Timer1 or any other enabled interrupt should be wakeup the processor, it's then continuing with the next instruction after sleep. I don't know why your processor is reset, but the reset cause may be checked. |
Posted: Sun Sep 28, 2008 2:28 am |
First, the compiler can set the OSCCON bit for you, without using direct bit accesses. Look at 'setup_oscillator'.
Now, the obvious 'not shown' thing, is the interrupt setup. To wake from sleep, the timer1 interrupt, must be enabled.
Have a look at the thread here a few days ago, about how to wake from sleep on the RDA interrupt. I list in this, the settings that are needed (obviously change to use the tmer interrupt).
It does work, when everything is setup right.
Posted: Sun Sep 28, 2008 5:05 am |
Sorry, for explaining what I want one more time.
I use Timer1 as RTC clocked as in Datasheet 2455 section 16.6 it’s running fine. And it must be running when in SLEEP mode. Furthermore the Timer1_int must be working.
When there are no action on the keyboard the 2455 is going to SLEEP. Wakeup I use int change on port B. But the running Timer1 int is waking the 2455 every 1 sec.
I don’t understand the function of using RTC together with SLEEP, because the int from Timer1 will wake the 2455 every 1 sec. |
Posted: Sun Sep 28, 2008 9:06 am |
Fixed:-)
My sleep mode is SEC_IDLE, the PIC is then cycling on Timer1 therefore my RTC is still working.
The Timer1 int will bring the PIC out from sleep every 1sec. therefore the loop while (SleepMode)... and the global var SleepMode.
But now project is working:-)
Thanks for the help in the forum.
Code: | #INT_RB
if (!input(_sw1) && (SleepMode)) //only _sw1 down and in sleepmode!
SleepMode = false;
Code: | //mesured 140uA in sleep mode, and 18mA in runningmode...
void Go_To_Sleep(void){
//set all pin to minimal load:-)
output_float(_led_r);
output_float(_led_g);
output_float(DS18B20_IO);
output_high(nok_cs); //disable the display
output_float(nok_dc);
output_float(nok_res);
output_float(nok_sclk);
output_float(nok_sda);
delay_ms(10); //just in case
SleepMode=true;
bit_set(OSCCON,7); //enter SEC_IDLE mode
bit_clear(OSCCON,1);//-
bit_set(OSCCON,0);//-
while (SleepMode) //my global var for starting it all up again:-)
Sleep();
#asm
nop
nop
#endasm
#asm
nop
nop
#endasm
//restore to normal
setup_oscillator(OSC_8MHZ|OSC_INTRC);
delay_ms(10);//wait i know it long but...
//from here we are running in not sleeping mode...
Posted: Sun Sep 28, 2008 9:08 am |
delay_cycles(1); Gives you a nop (you only need one). Generally, if using a compiler, let the compiler do the work. Only use assembler, and direct accesses, if there is a problem with the compiler.
