				 Posted: Sat Sep 27, 2008 11:59 am     |
				There is no CCS function to read the latch registers.  But you can use
a #byte statement to declare the register addresses, and then read
them directly, in code.  Example:
 	  | Code: | 	 		  #include <18F452.H>
#byte LATA = 0xF89
#byte LATB = 0xF8A
#byte LATC = 0xF8B
#byte LATD = 0xF8C
#byte LATE = 0xF8D
int8 value;
value = LATC;  // Read the latch register for Port C
The register addresses come from this section of the PIC data sheet:
 	  | Quote: | 	 		  | TABLE 4-1: SPECIAL FUNCTION REGISTER MAP |
