baumgarcX Guest
power-on reset execution |
Posted: Mon Sep 22, 2008 3:15 pm |
My 16F887 processor does not execute code following power-on resets. It appears to need a hard reset of the MCLR line before it runs.
I vaguely remember having this trouble initially with the 877 processor a ways back.
Is there a line in the .H that helps it wake up after power-on? Or a trick to the MCLR line other than a 47k pull-up?
I removed a lot of extraneous stuff from the standard .H, but it did not seem to help.
.H used
#include <16F887.h>
#device adc=10
#FUSES
#use delay(clock=20000000)
#use i2c(master, sda=PIN_C4, scl=PIN_C3)
Thanks |
Posted: Mon Sep 22, 2008 5:17 pm |
Quote: | I removed a lot of extraneous stuff from the standard .H, |
Don't ever do this. Restore the original 16F887.H file.
The following program will blink an LED on pin B0.
Code: | #include <16F887.H>
output_high(PIN_B0);
output_low(PIN_B0);
This code assumes that you have a 20 MHz crystal (and associated
capacitors) connected to the PIC. |
