Write_eeprom()
prwatCCS
Write_eeprom()
PostPosted: Thu Sep 18, 2008 10:22 am     Reply with quote
I am using PCWH 3.249 and PCWHD 4.073.
PIC 18F252
At background in my code I call write_eeprom(), but as it masks interrupts for the entire time it takes to write data to the internal eeprom, I have difficulty in servicing other interrupts adequately.
From the compiler I get (same results from both versions of compiler)
CCS compiler code masking interrupts for duration of EE write cycle
....................    write_eeprom(offset,data);
0C14:  MOVFF  136,FA9
0C18:  MOVFF  137,FA8
0C1C:  BCF    FA6.6
0C1E:  BCF    FA6.7
0C20:  BSF    FA6.2
0C22:  MOVFF  FF2,00
0C26:  BCF    FF2.6
0C28:  BCF    FF2.7
0C2A:  MOVLB  F
0C2C:  MOVLW  55
0C2E:  MOVWF  FA7
0C30:  MOVLW  AA
0C32:  MOVWF  FA7
0C34:  BSF    FA6.1
<<  >>                              why is the re-enable of interrupts not here ??
0C36:  BTFSC  FA6.1         ** this line spins until write complete
0C38:  BRA    0C36           **typ 4ms according to datasheet
0C3A:  BCF    FA6.2
0C3C:  MOVF   00,W           ** this is the bit that re-enables irq
0C3E:  IORWF  FF2,F
0C40:  MOVLB  0
0C42:  RETLW  00
My analysis of the 18F252 data sheet suggests interrupts only need to be disabled whilst we "unlock" the device and start the actual write cycle.
Is there a known switch in the CCS compiler that re-enables irq at the point I have marked above ??
I have tried the #device WRITE_EEPROM=ASYNC, but that seems to result in unreliable writes to the EEPROM. It places the check for write competion on entry to the code, which means I can exit and attempt a read BEFORE the write has actually completed ....
any ideas
regards
Peter Willis
Development Director
Howard Eaton Lighting Ltd UK
PostPosted: Thu Sep 18, 2008 11:36 am     Reply with quote
I don't know if write_program_eeprom and write_program_memory are faster than write_eeprom. You could check. And then you could write your data somewhere at the end of the program memory space. I think you can also write blocks of 64 bytes with write_program_memory ... that surely should be faster.
Just a guess ... good luck
