joe2008
| problem of main application jump with bootload function |
Posted: Sun Nov 23, 2008 10:05 pm |
Devcie:16F886
MPLAB:V8.10
CCS C complier: V4.049
Bootload area:0x0000-0x2FF.
configure:#fuses HS,NOPUT,BROWNOUT,NOLVP,NOCPD,NOPROTECT,NOWDT
My project includes two C source files.
One is bootload.C
| Code: | #define CONST_USER_CODE_START_INTR_ADDR 0x300 //user code area start - interrupt vector
#define CONST_USER_CODE_JUMP_ADDR 0x1200 //user code jump vector - allow max intr context save code
#build ( reset = CONST_USER_CODE_JUMP_ADDR, interrupt = CONST_USER_CODE_START_INTR_ADDR )
//#org CONST_RESET_VECTOR_START_ADDR,CONST_BTLDR_MAIN_END_ADDR {}
//================================================================== (Bootloader Embedded - ROM Implementation)
#rom 0x0000 = { 0x3000, 0x008A, 0x2821, 0x0000, 0x00FF, 0x0E03, 0x0183, 0x00A1 }
#rom 0x0008 = { 0x080A, 0x00A0, 0x018A, 0x3003, 0x008A, 0x2B00, 0x0009, 0x3FFF }
#rom 0x0010 = { 0x0041, 0x0041, 0x0032, 0x0035, 0x0034, 0x0032, 0x0030, 0x004C }
#rom 0x02F8 = { 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF }
#endif |
Another is main.C, including bootload.C and other header file.
sys_init(); // Configure I/O ports, peripherals, interrupts, timers & buffers.
epow_on = 1;
inrush_en = 1;
main application();
The problem is:
If application is not so large, the main application vector jump is correct.
Pls refer to below disassembly listing.
1200 3000 MOVLW 0
1201 008A MOVWF 0xa
1202 2EB7 GOTO 0x6b7
1203 0000 NOP
108: void main()
109: {
06B7 0184 CLRF 0x4
06B8 1383 BCF 0x3, 0x7
06B9 301F MOVLW 0x1f
06BA 0583 ANDWF 0x3, F
06BB 1683 BSF 0x3, 0x5
But if the application code is more larger, the main application vector
jump will be not correct. Pls refer to below disassembly listing.
1200 3000 MOVLW 0
1201 008A MOVWF 0xa
1202 2800 GOTO 0
1203 0000 NOP
108: void main()
109: {
0800 0184 CLRF 0x4
0801 1383 BCF 0x3, 0x7
0802 301F MOVLW 0x1f
0803 0583 ANDWF 0x3, F
0804 1683 BSF 0x3, 0x5
0805 1703 BSF 0x3, 0x6
Build result: Memory usage: ROM=26% RAM=38% - 42%
0 Errors, 12 Warnings.
I have bootloaded PIC18F4520 successfully with same method before, the application is more complex than this, and main application can jump correctly and runs no problem. Why is main application jump not correct with larger main application for PIC16886 ? |
Posted: Mon Nov 24, 2008 4:33 am |
It is very difficult to understand what you are doing from your description. You don't normally include the bootloader, in your application, which is what you seem to be showing.
However the obvious 'guess', is that on your larger version, the interrupt handler code, which you are writing at address 300, has got larger than 3840 bytes, meaning it no longer fits in the area you are allocating for it.
Normally, I'd suggest providing the 'default' layout for the interrupt handler, by placing its's code eight addresses above the main start location. This then allows the compiler to decide how much space it needs, and vector the initialisation jump to this.
joe2008
Posted: Mon Nov 24, 2008 9:11 am |
Ttelmah,
Firstly thanks your reply.
The part from #rom 0x0000 to 0x02FF are my bootloader. I has built my bootloader into hex file and don't list them out completely.
My interrupt handler is very simple, and don't occupy so much program memory.
I have noticed that if the size of my application is larger than 0x0800, it will jump error. If the size of my application code is not larger than 0x0800, it will jump correctly. I have checked the spec of PIC16F886,and find that one page of program memory is 0x0800. But I don't find what's relationship between them.
Anyway I'll try according to what you said. |
Posted: Mon Nov 24, 2008 10:08 am |
What I don't understand, is why the bootloader is present at all. The main application code, should not have any reference to the bootloader at all, except in it's relocated start address. You are showing the code, as if you are including the bootloader file in the final application.
Now, the obvious question, is what do you mean by your 'application'. Are you actually refering to the 'main'. If so, you may well need to be using more routines, to split this up. Basically, on the 16 chips, you are dealing with paged memory, and the compiler needs to be dealing with multiple small sections of code, which it can re-order to make things fit. Normally it'll complain if it can't fit things (giving an 'out of ROM' error, despite there being plenty of actual space still available). A search here wll find lots of threads about how to split up your code to avoid this. What I think is happening, is that you slightly 'odd' jump vector layout, is preventing the compiler from giving this error message, despite actually hitting this problem. On the 16 chips the normal location for the interrupt vector would be 4 locations above the boot entry point - 8 for 18 chips.
joe2008
Posted: Mon Nov 24, 2008 9:05 pm |
Sorry, I think I need give more details about the problem and program.
Now I updated I2C_Bootloader_PIC16F886_Library_2.01.c as below:
| Code: | #define CONST_USER_CODE_START_INTR_ADDR 0x304 //user code area start - interrupt vector
#define CONST_USER_CODE_JUMP_ADDR 0x300 //user code jump vector - allow max intr context save code
#rom 0x0018 = { 0x0000, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF }
#rom 0x0020 = { 0x3FFF, 0x0184, 0x1383, 0x301F, 0x0583, 0x1683, 0x1703, 0x1587 }
#rom 0x0028 = { 0x3008, 0x1303, 0x0099, 0x3002, 0x009A, 0x30A6, 0x0098, 0x3090 }
#rom 0x0030 = { 0x1283, 0x0098, 0x1683, 0x1703, 0x0809, 0x39C0, 0x0089, 0x1303 }
#rom 0x02F8 = { 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF, 0x3FFF } |
Main.C as below:
#include "I2C_Bootloader_PIC16F886_Library_2.01.c"
#include <16F886REG.h>
#include <Software_UART.h>
#include <MASTER_ADM_I2C_MODULE.h>
#include <MATH.h>
epow_on = 1;
inrush_en = 1;
restart_wdt(); // Restart watchdog timer.
acquire_adc(); // ADC procedures.
detect_epow(); // Early Power Off
inrush_control();
PWM_CONTROL();
temp_monitor(); // Monitor PFC Temp
refresh_bulkok(); // PFC Bulk Control
fnUART_EVENTS();
The procedure of my program will be:
First run into initial start address(0x0000), and jump to 0x300 if don't meet bootload mode. Then jump to start address of "main" of main.C and run application code.
Now I build the project file and don't show any errors:
| Code: | Memory usage: ROM=26% RAM=38% - 42%
BUILD SUCCEEDED: Tue Nov 25 10:38:10 2008 |
Then I pursue the procedure by watching disassembly listing.
| Code: | [color=red]0300[/color] 3008 MOVLW 0x8
0301 008A MOVWF 0xa
0302 2800 [color=red]GOTO 0[/color]
0303 0000 NOP
0304 00FF MOVWF 0x7f
0305 0E03 SWAPF 0x3, W
0306 0183 CLRF 0x3
0307 00A1 MOVWF 0x21 |
032B 0E21 SWAPF 0x21, W
032C 0083 MOVWF 0x3
032D 0EFF SWAPF 0x7f, F
032E 0E7F SWAPF 0x7f, W
032F 0009 RETFIE
0330 118A BCF 0xa, 0x3
0331 120A BCF 0xa, 0x4
0332 2B33 GOTO 0x333[/code]
| Code: | 107: void main()
108: {
[color=red]0800 [/color] 0184 CLRF 0x4
| Code: | 823: #INT_EXT
824: void service_RB0(void)
825: {
826: INTCON_INTF=0; //must cleared in software
0333 108B BCF 0xb, 0x1
827: PWM_wait_cntr++; //For PWM control delay
0334 0ABE INCF 0x3e, F
828: // get sum of AC input voltage, put into i8_acv7
829: i8_acv7 = i8_acv2; // Save the ave value, for the last 10ms
0335 0838 MOVF 0x38, W
0336 00BC MOVWF 0x3c
0337 0837 MOVF 0x37, W |
My problem is it seems don't jump to 0x800 which "main" start when jump out bootload mode, while not any build error. |
