ndineshbabuece@gmail.com Guest
| ADC not working in 16f676 |
Posted: Sun Sep 14, 2008 11:40 am |
The ADC is not working properly in PIC16F6776.
The following is the code I have tried:
| Code: | #include <16F688.h>
#fuses HS, MCLR
#DEVICE ADC=10
int16 ch_result=0;
SETUP_COMPARATOR(NC_NC_NC_NC);
setup_vref(FALSE);
SET_TRIS_A( 0x00 );
set_TRIS_C(0x0f);
setup_adc_ports( sAN1 | VSS_VDD);
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel(1);
delay_ms(10);
ch_result=0;
ch_result=read_adc();
ch_result&=0xfff8;
if(ch_result>=3)
output_high(PIN_A0);
if(input(PIN_C0))
delay_ms(1);
if(!input(PIN_C3))
{ delay_ms(1);
output_high(PIN_C4);
else if(input(PIN_C3))
output_low(PIN_C4);
output_low(PIN_C5);
output_low(PIN_A2);
else if(!input(PIN_C0))
output_low(PIN_C4);
output_low(PIN_C5);
output_low(PIN_A2);
if(!input(PIN_C1))
delay_ms(1);
if(!input(PIN_C3))
delay_ms(1);
output_high(PIN_A2);
output_low(PIN_C4);
output_low(PIN_C5);
output_low(PIN_A2);
else if(input(PIN_C1))
output_low(PIN_A2);
if(!input(PIN_C2))
delay_ms(1);
if(!input(PIN_C3))
delay_ms(1);
output_high(PIN_C5);
output_low(PIN_C4);
output_low(PIN_C5);
output_low(PIN_A2);
else if(input(PIN_C2))
output_low(PIN_C5);
output_low(PIN_A0);
output_low(PIN_C4);
output_low(PIN_C5);
output_low(PIN_A2);
The input channel gets loaded i.e., when I apply 0.4V as input, and testing in the pin at channel, the input current draws. I don't know the reason. Can any body help ? |
Posted: Sun Sep 14, 2008 1:25 pm |
What chip are you actually using?.
You say '16F6776' - no such chip. If you mean 16F676, the code is being compiled for a 16F688. Needs to be corrected...
The pin you use as an ADC input, needs to be set as an input, not an output. Either set it correctly, or remove the TRIS statements (the compiler will set TRIS for you).
As a 'comment', (not causing the problem, but will cause inaccuracy problems), look in the data sheet, for what ADC clocks are legal. If this is the 676, Note 4, under table 7-1.
| regarding PC16F676 |
Posted: Sun Sep 14, 2008 10:49 pm |
| Ttelmah wrote: | What chip are you actually using?.
thank you sir i got the result |
| flicker problem |
Posted: Mon Sep 15, 2008 1:50 am |
Using PIC 16f676 I activate an output if the input occurs. Now I have problem when I switch on my circuit power unnecessarily the o/p goes high.
ie it flickers each time when I switch on my power.
But it does not happen when I am using PIC16F677A.
Can I know the reason ?
How can I rectify this problem ? |
