attabros
| RS232 problem |
Posted: Thu Sep 11, 2008 4:47 am |
Hi
I m tring to send data from controller to PC using PIC16F877A
& MAX232 firt i try just by sending "hello world" to PC using hyper
terminal,
I made the following code but dit does not work.
#include <16F877A.h>
#device adc=8
#FUSES XT //Crystal osc <= 4mhz
#FUSES PUT //Power Up Timer
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
// TODO: USER CODE!!
while (TRUE)
printf("Hello World: \r\n");
is the code correct if not what will be the other possibilities to make it work
i have checked the hardware connections
i connect PIN 25 (TX) of controller to PIN 11 of MAX, PIN26 (RX) of
controller to PIN 12 of MAX on the other side on RS232 connector PIN 2 to 14 of MAX & PIN 3 to 13 of MAX & PIUN 5 ground. |
RLScott
| Re: RS232 problem |
Posted: Thu Sep 11, 2008 5:35 am |
What do you see on pin RC7 when you look at it with a scope? _________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting |
MicroManiac
Posted: Thu Sep 11, 2008 6:34 am |
What clock are you using???
i noticed that you are using an XT clock which should be less then 4Mhz
but in the code you are using #use delay(clock=20000000)
This will not work if you are using XT clock
Try it and let me know _________________ "Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
Albert Einstein |
drh
Joined: 12 Jul 2004 Posts: 193 Location: Hemet, California USA
Posted: Thu Sep 11, 2008 8:19 am |
Change this:
| Quote: | | #FUSES XT //Crystal osc <= 4mhz |
to this:
#FUSES HS
and try again. _________________ David |
attabros
Posted: Thu Sep 11, 2008 10:27 pm |
#fuses HS
it works THANKS |
