		| View previous topic :: View next topic   |
			nverma Guest
				| Storing a large 2D structure in program eeprom |
				 Posted: Wed Sep 03, 2008 1:34 am     |
				Hi Everyone,
I am trying to create a 2D structure that has 3 elements that are all integers.  Obviously, the structure was too big for RAM, now I have to store it in program memory and am running into some issues.  I'm using a PIC18F8722.
I define the structure and the size and the place in memory to store it in using the addressmod statement.  Then later on in the code, I define the actual content of each structure element.  My problem is that when I try to find out by reading back the contents of the structure, some locations have the correct data and some don't.  My guess is that my definition of the structure in memory is not correct and is messing up the address of the defined elemets.  Here's my code below:
#include <18F8722.h>
#device ADC=10
#include <stdio.h>
#include <math.h>
#include <ctype.h>
#include <stdlib.h>
#fuses H4,NOWDT,NOLVP
#use delay(clock=40000000)
#use rs232(baud=2400, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8)
void DataEE_Read(int32 addr, int8 * ram, int bytes)
   int i;
   for(i=0;i<=bytes;i++,ram++,addr++)
      *ram=read_program_eeprom(addr);
void DataEE_Write(int32 addr, int8 * ram, int bytes)
   int i;
      write_program_eeprom(addr,*ram);
addressmod (DataEE,DataEE_Read,DataEE_Write,0x07FFE,0x1FFFE);
struct   swvar{
int DataEE   x;
int DataEE   y;
int DataEE   io_test_pin;
struct   swvar   DataEE   swtest[32][60];
short insertion[32];
void io_meas(void);
void map(int insertion);
   long   i   =   0;
   int   insert_count   =   0;
   int   sw_count      =   0;
   int   io_count      =   0;
   for(i = 0; i < 32; i++)
      insertion[i]   =   0;
   insertion[29]   =   1;
   for(insert_count = 0; insert_count < 32; insert_count++)
      for(sw_count = 0; sw_count < 60; sw_count++)
         swtest[insert_count][sw_count].x   =0;
         swtest[insert_count][sw_count].y   =0;
      if(insertion[i]   ==   1)
         map(i);
   io_meas();
void io_meas(void)
   int i   =   0;
   int j   =   0;
   int   check      =   0;
   unsigned int   test1   =   0;
   unsigned int   test2   =   0;
         for(j = 0; j < 60; j++)
         test1   =   swtest[i][j].x;
         test2   =   swtest[i][j].y;
         printf("Insertion = %d\r",i);
         printf("Switch = %d\r",j);
         printf("x CTRL = %u\r",test1);
         printf("y CTRL = %u\r",test2);
   return;
   switch(insertion)
      case 29:
         swtest[29][0].x = 59;
         swtest[29][1].x = 60;
         swtest[29][2].x = 61;
         swtest[29][3].x = 59;
         swtest[29][4].x = 60;
         swtest[29][5].x = 61;
         swtest[29][6].x = 59;
         swtest[29][7].x = 60;
         swtest[29][8].x = 61;
         swtest[29][9].x = 59;
         swtest[29][10].x = 60;
         swtest[29][11].x = 61;
         swtest[29][0].y = 176;
         swtest[29][1].y = 177;
         swtest[29][2].y = 240;
         swtest[29][3].y = 241;
         swtest[29][4].y = 242;
         swtest[29][5].y = 178;
         swtest[29][6].y = 182;
         swtest[29][7].y = 183;
         swtest[29][8].y = 246;
         swtest[29][9].y = 247;
         swtest[29][10].y = 248;
         swtest[29][11].y = 184;
         swtest[29][0].io_test_pin = 25;
         swtest[29][1].io_test_pin = 25;
         swtest[29][2].io_test_pin = 25;
         swtest[29][3].io_test_pin = 26;
         swtest[29][4].io_test_pin = 26;
         swtest[29][5].io_test_pin = 26;
         swtest[29][6].io_test_pin = 23;
         swtest[29][7].io_test_pin = 23;
         swtest[29][8].io_test_pin = 23;
         swtest[29][9].io_test_pin = 27;
         swtest[29][10].io_test_pin = 27;
         swtest[29][11].io_test_pin = 27;
   return;
I'm trying to store the structure in the bottom half of the program eeprom from 0x07FFE to 0x1FFFE to ensure it doesn't overlap the program code.  Could someone help me to find out what the problem is.  Maybe i'm not using the addressmod command correctly...
Thanks |
			FvM
				 Posted: Wed Sep 03, 2008 2:12 am     |
				| I can't compile the code without errors, cause the DataEE type modifier is used incorrectly in swvar definition. (With PCH V4.078). When omitting DataEE in the struct definition, the code compiles and seems to operate meaningfully (a first view). |
			nverma Guest
				 Posted: Wed Sep 03, 2008 2:20 am     |
				I can get my code to compile with the following statement, i'm using 4.047:
If I remove the DataEE from the above statement, the compiler complains about not enough RAM, hence why I'm trying to store the structure in the program eeprom.  So when you compiled the code, you didn't get a RAM error?
And what can I do to resolve the DataEE function?  I just need the entire structure to fit somewhere in memory, doesn't matter where...
Thanks |
