| Compiler errors PCM |
Posted: Mon Jul 21, 2008 12:29 pm |
Hi
I get this error when compiling.
Executing: "C:\Program Files\PICC\Ccsc.exe" +FM "main.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 111 "main.c" Line 2(7,40): Unknown keyword in #FUSES "NOPROTECT)"
1 Errors, 0 Warnings.
For some strange reason my preprocessors look like this
| Code: | #include <16F690.h>
#fuses NOWDT,INTRC_IO,NOPUT, NOPROTECT)
#use delay (clock=4000000)
#use rs232(baud=2400,parity=N,xmit=PIN_B7,rcv=PIN_B5,bits=9) |
and header file(s) looks like this (Don't know why)
//////// Standard Header file for the PIC16F690 device ////////////////
#device PIC16F690
#nolist
//////// Program memory: 4096x14 Data RAM: 253 Stack: 8
-------snip--------
long CCP_1;
#byte CCP_1 = 0x15
#byte CCP_1_LOW= 0x15
#byte CCP_1_HIGH= 0x16
------snip--------
#define COMP_T1_GATE 0x2000000
#bit C1OUT = 0x11B.7
#bit C2OUT = 0x11B.6
////////////////////////////////////////////////////////////////// VREF
// Constants used in setup_vref() are:
------snip--------
#define INT_RB7 0x1800B08
#list
It seems that all of a sudden the header files changed ??
regards |
Posted: Mon Jul 21, 2008 1:13 pm |
| Quote: | | #fuses NOWDT,INTRC_IO,NOPUT, NOPROTECT) |
The problem is obvious. You have an extra character on the #fuses line.
Please learn to fix these problems. |
Posted: Mon Jul 21, 2008 3:47 pm |
sorry for asking a stupid question.
