Daniel Hirschybar Guest
| output_high automatically reverting on next output_high |
Posted: Tue Apr 01, 2003 8:49 pm |
Hi All,
I am a beginner, and running into a seemingly simply issue:
The description:
I'm using a pic F877. If I set pin D2 HIGH, give it a delay of say 1 sec, and then set pin D3 HIGH, it will automatically turn pin D2 LOW or OFF without my specifying it.
Lets say I want to have 3 pins to remain HIGH permanently (or at least whenever I want them to remain on). This problem is ensuring that I can only have one pin high at a time.
Things I've tried:
#use standard_io(A-E) makes no difference.
SET_TRIS_A-E(0x00) makes no difference
ouput_d(0b00000100);
ouput_d(0b00001100);
Also does the same thing.
Anyway, any suggestions would be absolutely welcome! I am truly stumped.
Thanks in advance!
Daniel
Heres my current VERY SIMPLE TESTING PROGRAM:
#include <16F877.h>
#fuses XT,WDT,NOPROTECT
#use delay (clock=4000000)
main()
setup_wdt(WDT_2304MS); /*unneccessary - but here it is*/
output_high(PIN_D4);
delay_ms(250);
output_low(PIN_D4);
set_tris_d(0x00);
output_low(PIN_D2);
output_low(PIN_D3);
while (TRUE)
restart_wdt();
output_high(PIN_D2);
delay_ms(250);
output_high(PIN_D3);
delay_ms(250);
___________________________
Original Post ID: 13300 |
| Re: output_high automatically reverting on next output_high |
Posted: Tue Apr 01, 2003 9:14 pm |
:=Hi All,
:=I am a beginner, and running into a seemingly simply issue:
:=The description:
:=I'm using a pic F877. If I set pin D2 HIGH, give it a delay of say 1 sec, and then set pin D3 HIGH, it will automatically turn pin D2 LOW or OFF without my specifying it.
1. What happens if you comment out all the Watchdog timer stuff.
(including changing the fuse to NOWDT) Does it still do this ?
I'm trying to find out if it's some problem with the ports, or
if it's caused by the WDT.
2. Also, you should add NOLVP to the end of your #fuses, unless
you know for certain that you're using low voltage programming.
3. What's your version of the compiler ? There once was a
problem with TRIS on ports D and E. See the following line
from the old CCS versions page:
3.052 SET_TRIS_D and E were broke in 3.050,3.051 now restored
4. Do have you anything connected to these Port D pins, such
as LEDs, without a series resistor ? (just wondering).
Original Post ID: 13301 |
Rainer Guest
Posted: Wed Apr 02, 2003 6:19 am |
Is the connection to the ground o.k.?
Is your power supply o.k.?
Original Post ID: 13306 |
