fbinotti
| hardware usart problem with pic 16f688 |
Posted: Wed Jul 09, 2008 9:41 am |
I can't use the hardware uart, with the FORCE_SW parameter the communication is good.
My pcwh version is: 4.062
#include <16F688.h>
#device adc=8
#FUSES PUT //Power Up Timer
#use delay(internal=4M)
//WORK.....
#use rs232(baud=2400,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8,stream=PC,FORCE_SW)
//DON'T WORK
//#use rs232(baud=2400,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8,stream=PC) //HARDWARE UART
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_vref(FALSE);
while(true)
fprintf(PC,"Test 232\n\r");
} _________________ -----------------
Fabrizio Binotti |
Posted: Mon Jul 14, 2008 7:15 am |
| were you able to get the HW uart working? If not, post a reply and I can send you code I have used on the 16f688 using the HW uart. |
guest1 Guest
Posted: Mon Jul 14, 2008 8:19 am |
| Maybe you need to set the TX pin as an output. It's possible that the software UART code does this for you. Using the hardware you have to do it yourself. |
fbinotti
Posted: Mon Jul 14, 2008 12:53 pm |
The problem was solved in
CCS PCM C Compiler, Version 4.076, 41428
Thank you. _________________ -----------------
Fabrizio Binotti |
