Lion Guest
| The problem about usart command. |
Posted: Fri Jun 27, 2008 11:02 pm |
I got a problem about usart on CCS C Compiler.
I am using CCS on PIC 16f877 and C18 C compiler on PIC 18f452.
My problem is that I can use the command which is UARTOpen(baud rate) to control the usart in PIC 18f452 to send data to another microcontroller with the A7eng. eb501 bluetooth but I do not find any similar command in CCS C compiler.
Does anyone know that is there any similar function or command to use?
I read the reference manual and the "#use rs232" is the only command which I can find in the reference manual.
any help will be appreciated.
Thank you very much.
Sincerely,
Brian |
Posted: Sat Jun 28, 2008 2:16 am |
#use rs232, is the command.
If you want to change the baud rate _after using this_, there is a separate 'set_uart_speed' command.
Also, remember that with CCS, you have 'symbolic' UART 'streams', so you can setup the same UART with multiple #use statements, and access the settings you want, by just selecting the stream name.
It is actually quite a 'nice' part of the language.
Lion Guest
| The command about usart problem. |
Posted: Sat Jun 28, 2008 1:03 pm |
| Ttelmah wrote: | #use rs232, is the command.
Thank you for your reply.
I am really new beginner on this. Could you explain what do you mean "'symbolic' UART 'streams'". ? Could you give some example?
Sincerely,
Brian |
tranz
Lion Guest
Posted: Mon Jul 07, 2008 1:13 am |
Hi Tranz,
I am reading the content now.
Thank you for your help.
Sincerely,
Brian |
