CCP module on PIC16F877
Wayne Siebrecht
PostPosted: Mon Mar 31, 2003 7:23 pm     Reply with quote
I would like to capture two separate variable duty cycle singals and I was wonding if there was a simple way to do it with the CCP module on the PIC16F877. Flipping the interrupts back an forth from rising to falling edge seams to be the way, but I can't seam get it right and it is very confusing. Is there a more elegent method. I haven't found a good example or anything even close for a guide using the CCP. Any ideas?
Original Post ID: 13270
Re: CCP module on PIC16F877
PostPosted: Tue Apr 01, 2003 2:07 pm     Reply with quote
:=I would like to capture two separate variable duty cycle singals and I was wonding if there was a simple way to do it with the CCP module on the PIC16F877. Flipping the interrupts back an forth from rising to falling edge seams to be the way, but I can't seam get it right and it is very confusing. Is there a more elegent method. I haven't found a good example or anything even close for a guide using the CCP. Any ideas?
Have you looked at the CCS example file, EX_CCPMP.C ?
Also, see these links:
AN594 -- Using the CCP modules:
<a href="http://www.microchip.com/download/appnote/devspec/16cxx/00594b.pdf" TARGET="_blank">http://www.microchip.com/download/appnote/devspec/16cxx/00594b.pdf</a>
Reference manual on the CCP:
<a href="http://www.microchip.com/download/lit/suppdoc/refernce/midrange/midsect/31014a.pdf" TARGET="_blank">http://www.microchip.com/download/lit/suppdoc/refernce/midrange/midsect/31014a.pdf</a>
Original Post ID: 13292
