matiasnabarro
| Floats & printf not working under certain conditions |
Posted: Sun Jun 15, 2008 1:52 pm |
Hello: I'm having trouble with the next code. PCH 4.068.
When I comment the declarations of the char arrays sized 12 and 16, the code prints the correct string, when I use those arrays, the code prints garbage where it should print the float number.
Can anybody tell me what`s happening or better, how to fix it ?
Regards.
//the h file:
#include <18F4620.h>
#device adc=8
#FUSES NOIESO //Internal External Switch Over mode enabled
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES PUT //Power Up Timer
#FUSES NOSTVREN //Stack full/underflow will cause reset
#FUSES NOFCMEN //Fail-safe clock monitor enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOMCLR //Master Clear pin used for I/O
#use delay(clock=8000000)
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3,force_hw)
//now, the C
#include "Ctrl 4620.h"
#include <float.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define spi_sdo PIN_D0
#define spi_sck PIN_D1
#define EETripPoint 10 //direccion donde queda guardado el ultimo TP
#define EEAdcSpan 16
#define EEAdcZero 22
#define EEK0Cal 28
#define EEK1Cal 36
#define EESerialNumber 42
#define EERefresh 46
#define EEFirstRun 61
#define PULS_MAS PIN_B2
#define PULS_MENOS PIN_B3
#define PULS_RESET PIN_B4
#define OUT_1 PIN_B6
#define OUT_2 PIN_B7
#define AdcLsb 0.000625
#define ADCAddr 0b10010000
char cadena[4]="";
char parametro[12]="";
char buffer_out[16]="";
int p;
int idx;
float ifl=1;
float ADCFloat=0;
float AdcSPan=1;
float AdcZero=0;
float K1cal=1;
float K0cal=0;
int8 TP_Flag=0;
int8 Flag_Corte=0;
int8 i=0;
int8 Refresh=20;
int8 Puls_Timer=50;
int16 BTimer=234;
int16 CTimer=43;
int16 AdqTimer=25;
int16 DisplayTimer=10;
long SerialNumber;
signed long TripPoint=5000;
signed long Presion=0;
signed long AdcRaw=0;
setup();
printf("P=%u ifl=%1.3f\r\n",p,ifl);
p++;
ifl=p*0.2;
void setup()
//Inicialización general
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_OFF);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
Posted: Sun Jun 15, 2008 2:48 pm |
Try making the field width large enough.
The CCS printf, is not 'error checked', and will do daft things, if you give it starting values that don't work. In printf, the %x.yF format, specifies the _total_ field width as the first number, with the number of digits to place after the decimal as the second. You are asking it to print a field one character wide, and then put at least four characters into it (the decimal point, and three trailing digits). Now most printf's, when you ask to do this, will automatically increase the first number to be large enough, but the CCS one tends to go wrong in this type of setup.
It is a common error, because in some other languages, the first digit, is the number of characters to start with, in front of the decimal point. In C, this is not the case.
Try %5.3F
matiasnabarro
| Keep trying |
Posted: Sun Jun 15, 2008 8:22 pm |
Hi, I've tried the 5.3F and this is what I get at 232 output:
P=0 ifl=-777777.777
P=1 ifl=-333333.333
P=2 ifl=-333333.333
P=3 ifl=-;;;;;;.;;;
P=4 ifl=-333333.333
P=5 ifl=-777777.777
P=6 ifl=-;;;;;;.;;;
P=7 ifl=-111111.111
P=8 ifl=-333333.333
P=9 ifl=-555555.555
P=10 ifl=-777777.777
P=11 ifl=-999999.999
P=12 ifl=-;;;;;;.;;;
P=13 ifl=-0.000
I don´t understand.
Regards,
Matias. |
matiasnabarro
| Just simulator issue |
Posted: Sun Jun 15, 2008 9:06 pm |
Ttelmah: I simulating the code in Proteus VSM, with the error noted first. It runs ok on real hardware.
Thanks for your help.
Regards,
Matias., |
Posted: Mon Jun 16, 2008 2:16 am |
If you do a search here, you will find _lots_ of posts, where people think they have a problem, and then turn out to be using a simulator. Though simulators are 'great' for finding certain types of basic faults, unfortunately, none are perfect.
There are some 'real' problems with the CCS printf though, so being a bit careful is worthwhile (for instance, adding your own limit check on the range of incoming numbers), but in general, it does work.
Glad you have found the 'real' problem.
