TIMT
Joined: 02 Sep 2005 Posts: 49 Location: Nottingham, UK
| 18F66J50 DEVICE SUPPORT |
Posted: Thu Jun 12, 2008 5:44 am |
Hi All,
A quick question. I'm considering purchasing the latest version of CCS as I need to work on the 18F66J50 PIC. I've searched the forum for "18F66J50" but found no results. Has anyone had any experience of using CCS for this device? I would be gratefull if anyone who has, could let me know if they have experienced any problems (bugs) as I won't be buying the 12 month updates and I don't want to upgrade if this device is relatively untried (undebugged) with CCS.
Thanks, _________________ Tim |
bwhiten
| 18F67J50 |
Posted: Thu Jun 12, 2008 9:51 am |
I am using the 18F67J50 at present for USB, SPI, I2C, multi-channel A/D and RS-232. I have seen no outstanding issues with the compiler for this device. I AM using a hard coded PLL setup as recommended in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=33873&start=15
And I found an issue with the CCS USB driver that interferes with the SPI pins as shown in this link:
http://www.ccsinfo.com/forum/viewtopic.php?t=34799&start=15
A work around for this was pretty simple and only comes into play if you are using the first SPI pins and USB. |
TIMT
Posted: Thu Jun 12, 2008 10:09 am |
Thanks bwhiten, Interesting about the SPI and the USB interfering. I may well be using them. Saved me some grief there possibly! Looks like I will be upgrading then. - Unless anyone else has had any other issues.
Thanks again for taking the time.  _________________ Tim |
