george
| I/O trouble |
Posted: Tue Jun 10, 2008 11:32 pm |
Hello
I am using a pic 18f4580. I have a input that is always reading low. I am using a 10K pull up resistor to 5V. The digital input was working fine for about 1 hour of run time. Nothing abnormal electrically has taken place. Is it possible I am reading a internal buffer and not the output. I have tried reprogramming the chip and the pin still reads low when it is high. Pin d6 is the pin in question. Are there any settings I am missing? Can you reset the internal buffer by setting the pin to a digital output and setting it low/high and then resetting it back to a input?
Any help would be much appreciated.
PS. This is the second board that this has happened too.
Thanks Geo
| Code: | #zero_ram
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#use delay(clock=10000000)
# fuses HS,NOPROTECT,BROWNOUT,NOWDT,PUT, NOLVP,MCLR
set_tris_d(0b01000000);//D6 set to input for SWitch |
SherpaDoug
Posted: Wed Jun 11, 2008 7:50 am |
Way back when I used to work with PIC16C54s it was common knowledge that PIC TRIS direction bits sometimes got garbled. So I developed a programming style that reconfigures the TRIS registers each time through the main loop. I don't know if that problem persists, but I still use that style and I have no problems.
The datasheet should show you the structure of the pin buffers and let you know just where your input data is coming from. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Wed Jun 11, 2008 8:36 am |
The shown code fragment looks fine but is incomplete, the port reading part is missing. Post a small but complete program demonstrating your problem.
What is your compiler version number?
You are reading data from a switch. Whenever I read 'switch' I think 'debounce code'. What kind of switch is connected and what measures have you taken to solve the switch bouncing effects? |
Posted: Wed Jun 11, 2008 8:38 am |
If you are using standard_io (the default in CCS), and are using their I/O instructions (output_high etc.), then CCS will automatically set/clear the TRIS bits for every input/output instruction. With 'fast_io' selected this is removed.
Realistically, if the pin was reading OK, then either something has gone wrong in the code, or something 'abnormal electrical' _has_ taken place.
There is a separate _output_ latch, but the input latch, is directly wired to the pin, and is enabled, by the read operation. It'll latch whatever is there, when you start the read operation.
The 'fast_io' line is configuration change, so doesn't have to be inside the code, but the _tris_ line, is a program instruction, and needs to be inside the running code. As shown, it won't change the TRIS. I'd suspect this is the problem, though the default TRIS setting, would be for all pins to be inputs.
george
Posted: Thu Jun 12, 2008 8:57 am |
Thanks for the responses
Compiler version is
PCWHD 4.074
De bounce is done with hysteresis using a timer interrupt. Every 50 milliseconds the switch is read with this statement.
if(!input(PR_SW))
Port is initialized with startup routine called once before main loop.
set_tris_d(0b01000000);//D6 set to input for PR_SW
startup(); //initialize
while (true){
}// while(TRUE)
}//end of main
I had a closer look at the data sheet and noticed this portd uses Schmidt triggers for digital inputs
from data sheet
RD6/PSP6/
P1C
RD6 OUT 0 DIG LATD<6> data output.
IN 1 ST PORTD<6> data input.
Legend: OUT = Output, IN = Input, ANA = Analog Signal, DIG = Digital Output, ST = Schmitt Buffer Input, TTL = TTL Buffer Input
There is diode protection to VDD or VSS on this PIN.
However, I suspect the Pin was damaged electrically with an inductive load.
The chip was reprogrammed with and older version of software and the pin still did not read correctly.
Anyway thanks for all your help. If the second one has I/O problems then
I need to look very closely at the code. However if it was the code, would not the I/o pin be reset when it is reprogrammed?
Thanks Geo |
